**CLOSED** - Switch-Pros SP9100/SP8100 Power Module Mounting Tray - Group Buy**
CLOSED
Switch Pros Mounting Trays - VERTICAL Mounting! Why is it important to keep Switch Pros Power Module mounted Vertical? Switch Pros instructions state to keep the module vertical to allow warranty to be in effect. Why ruin your investment? **AS OF THIS MOMENT, THIS TRAY IS ONLY AVAILABLE FOR 5TH GEN 4RUNNERS** https://www.tacomaworld.com/media/fu...-1.648448/full https://www.tacomaworld.com/media/fu...-2.648449/full https://www.tacomaworld.com/media/fu...re.648450/full https://www.tacomaworld.com/media/fu...ed.648451/full https://www.tacomaworld.com/media/mo...nk.648452/full https://www.tacomaworld.com/media/mo...re.648453/full https://www.tacomaworld.com/media/mo...ut.648454/full Tray Only Options, for the do it "yourselfer": The Terminal Block Mount Tray - $100.00 The Fuse Block Mount Tray - $100.00 The Blank Mount Tray - $100.00 Mount Tray Accessory Packages, for the "full shabang": The Terminal Block/Blue Sea Package Mount Tray $140.00 includes: The Terminal Block Mount Tray Blue Sea Terminal Block 30A - 8 Circuit 2508 Blue Sea Common 150A BusBar - 10 Gang with Cover 2300 Ground Cable, BusBar to Battery, Black 316 SS Mounting Hardware The Fuse Block/Blue Sea Package Mount Tray $245.00, for the "I'm going all out": The Fuse Block Mount Tray Blue Sea ST Blade Fuse Block - 12 Circuits with Negative Bus and Cover 5026 Ground Cable, BusBar to Fuse Block, Black Blue Sea 285-Series Circuit Breaker - Surface Mount 100A 7187 Cable, Fuse Block to Circuit Breaker, Red Cable, Circuit Breaker to Battery, Red (16" or 24") Blue Sea Common 150A BusBar - 10 Gang with Cover 2300 Ground Cable, BusBar to Battery, Black 316 SS Mounting Hardware Discount: We need 20 participants for $20 off If we reach 40, I will ask the vendor to see if we can get an additional discount! Shipping is USPS Priority $14.35 (Hawaii and Alaska included) Fine Print 1. California Taxes apply for California residents. 2. A participant is someone that places a Mount Tray order, regardless of any accessories or amount of accessories purchased. Accessory purchases without a Mount Tray do not qualify for a discount. 3. Shipping to Canada (or any other place for that matter) is charged based upon actual cost of USPS Flat Rate Priority Box. For reference random Canadian 'TE' zip code, was just under $50.00. Any duties or taxes are the responsibility of the person its shipped to. 4. Hawaii and Alaska are included with shipping as quoted above. 5. Invoices will go out December 10th and need to be paid by end of day Friday December 13th. Packages will start shipping within a couple of days after its paid as long as stock holds out, after which there will be a 3 week backorder. If you are interested in this: Sign up by replying to this thread. Don’t chicken out. You are either in or you aren’t. NO maybe, no waiting on the wife, gf or bf to get permission. There is enough time to make up your mind or find a doctor to sell your kidney or pawn your wife’s jewelry. If you are on the fence to see if it’ll go up to max discount before you jump in, you are HOLDING the group buy back. Don’t be that dude. |
List:
1. 2. 3. |
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
