2002 Toyota 4Runner 5sp swap
Hey all. I've got an 02 4runner that blew the auto trans going up a hill. I dropped the pan and scooped a bunch of metal out so I figured I would go ahead and commit to dropping a manual in.
I am making a thread to just keep track of the process. It may or may not become informative or useful to others, but someone might find something helpful from it. As of now, I have removed the auto trans, mounted pedals and drilled the firewall for the master cylinder. My parts list so far is: manual transmission from 200 tacoma pedals master/slave cylinder driveshafts Parts I need to order: clutch/flywheel ??possibly starter if the auto is not compatible?? transmission xmember mount output shaft seal After Christmas I plan to order the remaining parts and put the manual in. I have not figured out what I am going to do about the wiring but it seems there are some options. I am going to try to maintain the 02 transfer case, but I do have the j-shift from the 00 tacoma. https://i.imgur.com/s1AoFcy.jpg https://i.imgur.com/Y914aN6.jpg https://i.imgur.com/NrHKxAX.jpg https://i.imgur.com/NFaYUvP.jpg https://i.imgur.com/NwyDOBO.jpg https://i.imgur.com/2gd1QdW.jpg |
Totally going to follow this! I’m piecing together the parts for a 5speed swap right now
Sent from my iPhone using Tapatalk |
Auto starter should work just fine. Also the cross member from auto should be fine. You’ll need a master cylinder line. eBay one for 93 Supra. Fits like a glove. I got it on mine. As far as wiring. You could trick the auto Ecu into neutral for mean time. But you’ll have check engine light. I don’t recall since it’s been long time. But 02 4runner should be plug and play with manual ecu. So I think a m/t ecu out of 2000 4runnee would be plug and play. I could be wrong. Again, been a while since something like this came up here.
I managed to grab the lines which was nice. I’ve got them run, just need to bolt the trans up.
The auto X-member works, just need to get the manual mount. As far as ecu, I was told 00-03 Tacoma ecu would hook right up. I’m mostly concerned with how I’ll retain the 02 transfer case. |
Quote:
-Charlie |
It seems to me that an ECU for a vehicle with a drive-by-wire throttle body - which to my knowledge is any 5VZ-FE 2001 and later - would differ significantly in its coding from an earlier my-foot-moves-the-throttle-plate engine.
And this is irrespective of whether the engine is mated to an automatic or a manual. Thus, the recommendation for a 2001 or later Tacoma ECU makes sense. |
Quote:
That's what I had to do on mine. Check out Tylers build he did a similar one to mine. I did not swap the wire harness. I just jumpered my AT harness and it worked just fine. |
Quote:
Quote:
It's a little aggressive for my driving style. Clutch is very "grabby" The Marlin clutch wasn't available at the time. I would go with on of those or the LCE Pro Clutch kit in retrospect. |
Quote:
Also, just re-use your old driveshafts. The M/T is 1.25” shorter than the A/T, there is enough travel in the slip yoke on the front driveshaft to compress it that much and I just put a 1.25” driveshaft spacer from Low Range Offroad on the rear driveshaft. Look at my build thread for more info. |
I am going to have a bunch of parts left over from my swap. I am pretty sure I will have all the wiring harnesses and 5-speed ECU from a '99. I will also probably have the master and slave cylinders and possibly a crossmember and maybe more stuff.
I should know for sure after Christmas. |
I think I am going to pick up this media blaster from Harbor Freight and clean up the r150f a little more.
Portable Abrasive Blaster Kit Waiting on a few parts to get here and wouldn't mind having it look a little better. |
Update coming soon. Everything is pretty much buttoned up. Just waiting on some MT-90 to get here and need to wire up the neutral override.
Well I’ve been stumped for a day or so. Trying to get the dang NSS wired so I can start it up.
I can’t find the proper wiring diagram for an 02 anywhere. I’ve got two plugs un used and I’m not sure which is which. https://uploads.tapatalk-cdn.com/202...897385fe4f.jpg https://uploads.tapatalk-cdn.com/202...2a7c1ececb.jpg Does anyone happen to know what wires to jump? Sent from my iPhone using Tapatalk |
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
