Has anyone had the 4.0 engine noise turn out to be an actual problem?
2013 Trail, currently at 97k miles.
I've spent hours reading all the threads on the 4.0 noises, but I just have a hard time mentally accepting that it's "normal" for a engine to sound like it has a rod knock. I see some people say it does it sometimes, or all the time, or only until it warms up. Mine always does it, regardless of the temperature or whether it's warmed up or not. The thing can be running for hours and sound the same as right after a 20* cold start. I swear it didn't do it when I bought it with 79k in Feb, I probably would have ran, not walked away from it had I heard that. Don't know what it had in it for oil when I bought it, I changed it with M1 0W20, and it made no difference. I just changed it again, this time with Valvoline full syn 0W20, and it sounds the same. 10k OCI. Anyone have it actually turn out to be some issue? |
Do you have a video of the sound?
Quote:
Someone in one of the other threads posted a link to his YT vid that sounds just like mine. |
106k miles here. Same sounds you are describing
Quote:
Mine sounds just like the one in that video. |
Ive been driving mine since new, at 187,000 miles now. I can say without a doubt that the noise in mine gets louder the longer it is since the last oil change. I started doing 5k changes based on that. I'm sure some will disagree with the 5k OCI, but like I said, without a doubt, I hear it get noticeably louder around the 5k mark. I've used all of the mainstream oils and landed on the TGMO when I was able to get the dealer to give it to me for around $6/qt.
As long as its on warranty, I don’t care. Hope it granades right before warranty is up.
Quote:
Quote:
Ok, haha, I guess I'll just have to learn to live with it.
I changed the oil a few hundred miles ago, Valvoline full syn 0W20. No change, makes the same noises. I saved some of the old oil for analysis, I'm going to send it to Blackstone soon. I may bite the bullet next time and spend the $$ on the Toyota branded oil to see how that does. |
In my other engines using a thicker oil always helped with engine noise, try using a 0w30 or 5w30 next oil change and see how it goes. It’s only 1 only change, worth a shot.
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
