Unable to program FOB/Doors not registering as open
2001 4runner limited. I went to program my FOB and I cannot enter programming mode. For some reason my truck is NOT registering any doors open. My interior lights don't come on and my instrument cluster door light does not come on when any of the 5 doors are open. I work a lot on 4runners and am a little puzzled by what can be causing this. Any help greatly appreciated. My key doesn't work in the door so I really need the FOB programmed.
Has one ever worked while you've owned it? The Limited did come with the remote door lock feature. The base and SR5 didn't.
It may be someone installed an aftermarket alarm system which requires on of their fob's or maybe you simply have a bad fuse or broken/disconnected wire. I would definitely do something about your key not working in the doors though. Re-key or change locks. |
There are no modifications to the car or the alarm system. It is all stock. I gutted the interior and the dash and put it back together (didn't work before the gutting). All 2001 SR5s should have FOBs. I've never seen one without it. I've programmed probably 10 of these and this one puzzles me. Its usually the door actuator sticking, but pretty sure the car isn't recognizing the driver door open during programming.
Quote:
Quote:
BE25-27 in my manual for troubleshooting |
Quote:
All 2002 models did though. I guess Toyota realized this should be standard equipment on the 4Runners by then. 2001 4Runner Specs |
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
