5th gen T4Rs
https://www.toyota-4runner.org/5th-gen-t4rs/)
amir_gh |
01-06-2020 09:33 AM |
What is this connector on 2016 4Runner Limited ?
Old Red |
01-06-2020 11:14 AM |
@ amir_gh
that is the electrical connection for the outside luggage compartment smart key antenna. This is the antenna that detects the presence of the smart key for when you push the buttons on the rear hatch to open and close the window on the limited only. Hope this helps.
amir_gh |
01-06-2020 11:45 AM |
Quote:
Originally Posted by Old Red
(Post 3419544)
@ amir_gh
Thanks very much
Sent from my SM-N975U using Tapatalk
amir_gh |
01-06-2020 12:37 PM |
(Post 3419544)
@ amir_gh
Two wires are stripped. Do I need the entire wire harness or I can just fix those two?
Thanks https://uploads.tapatalk-cdn.com/202...3aab07a9ef.jpg
Quote:
Originally Posted by amir_gh
(Post 3419591)
If the plug is good, just repair/reconnect the wire.
Old Red |
01-07-2020 12:23 AM |
(Post 3419591)
If it were me, I would repair the two wires and call it a day. Those two wires running to the key antenna run the entire length of the passenger side of the Limited, and are part of the right hand floor wiring harness (P/N 82161-35F50 for Limited and P/N 82161-35F60 for Limited with the auto steps is between $980-1050 for the wiring harness just looking online). Replacing the entire wire harness for that much money for two wires is overkill.
Order the two repair terminals for the connector and splice them in. If you need to order another connector, do so. Repairing the two wires should run you less than $40 at the dealership. I don't know the connector number off the top of my head, but on the wiring diagram it is listed as connector "N21". The parts counter should be able to figure it out from there.
Good Luck!
-Old Red
amir_gh |
01-09-2020 01:13 PM |
(Post 3420045)
Good Luck!
-Old Red
Thanks very much. This information helps me a lot
flyrv9 |
01-09-2020 02:49 PM |
Agreed, it looks like a simple repair. You can either reconnect or use a splice if you need length to make the connection. Also, I'd wrap that connector to prevent future damage. A thin piece of rubber and a couple ty-wraps should do it. It's hard to see from those pictures just how much wire you have to work with there.
amir_gh |
01-09-2020 03:42 PM |
Quote:
Originally Posted by flyrv9
(Post 3421459)
Thanks, I got these from dealer. They were relatively cheap.
- Housing Connector F 90980-12416
- Toyota Terminal Repair W W 82998-24250
amir_gh |
01-21-2020 03:28 PM |
(Post 3420045)
Good Luck!
-Old Red
Hello again,
I can't find the that male terminal that connects to keyless Antenna. I went to dealer and they couldn't figure it out. Here is the connector picture. I can't find any thing in wire harness diagram. Do you know by any chance?
Thanks again. https://uploads.tapatalk-cdn.com/202...c5aaee1cf9.jpg
Old Red |
01-21-2020 09:15 PM |
(Post 3428779)
Hello again,
@ amir_gh
, here you go. Terminal number 82998-24360. Sounds like your local dealer is not too motivated lol. Given the project you are doing, you might want to pay the $20 for 48 hours of Toyota TIS access so you can view the OEM repair manuals, and info and download what you need so that you have it on hand. I have found it more useful than my local parts counter at times.
amir_gh |
01-21-2020 10:07 PM |
(Post 3429023)
@ amir_gh
Your so awesome!:clap2: Thank you. Found the connector and repair terminals. I cant believe that little thing was delaying my project car LOL. I cant wait to finish it.
Housing Connector M
Part Number: 90980-12519
Part Number: 82998-24360
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
