Went Down the Rabbit Hole - Here's what I'm doing
99 SR5 4WD 3.4 - lifted and supercharged - well that's still in a box in my garage but going in soon, 3 pass radiator, Tundra 231mm
This weeks front end project Replace upper and lower ball joints - OEM Replace U/L CA Bushings - Whiteline Replace sway endlinks - Whiteline Replace outer tie rods - OEM Replace CV axles and seals - OEM Replace f/wheel bearings and seals - OEM Transmission Mount - OEM Cam Bolts I'm going into the wheel bearing project myself, will take them to a shop to have pressed IF I have to cross that road. Would appreciate tips if you got em |
Installation of the SC is real easy. The hardest part was the belt, lol. Have fun
good thing you aren't in the rust belt, my LCA bushing replacement was a nightmare, thankfully I have a press, but it was definitely worth it. for the LCA bushings I burned the old bushing out and then used a chisel to roll the edge of the old outer bushing sleeve inward, and then pressed it out using a big socket.
you can probably get away without the press and just hammer the sleeve out with a chisel but mine were basically a solid mass of rust. I installed aftermarket uppers on mine but I imagine it would be the same. I actually only had one seized alignment cam, the rest came off easily and I replaced them with the SPC ones that have the plastic sleeve to prevent seizing. end links, tie rods, CVs, etc are easy compared to those bushings, my tie rods were rusted together so I replaced inner and outer at the same time, but still not a very hard job/ |
Quote:
I'm pretty sure you know about our channel, but just in case, here's a link: YouTube
We have a video for every single thing you have listed you want to do to your rig. |
Quote:
Right now Im making a list of tools and socket sizes. Doing this with tools I have and Autozone loaners for the specialty stuff - tie rod puller, bushing press, bearing press. |
I bought a cheap set of 3 jaw pullers from harbor freight, I think it was like $30 and they work on all sorts of stuff so I would recommend getting those.
Quote:
Thankfully, rust wont be an issue. However the parts will go back on cleaner than ever I'm checking out the HF 3 Puller now |
Quote:
Mike |
Quote:
It's the one part that im uncertain about. Worst case, ill take the hubs to a shop Good to hear the rest is straight forward |
if you do all the control arm, ball joints, and CV work at the same time you will have the steering knuckle off, then just take it to a shop and have them swap the bearings. the knuckle isn't hard to remove
Quote:
Mike |
Before you put the supercharger on, run your gas tank down low and fill it
with premium 91 or 93 the highest you can find. Then drive it easy for the first tank of gas while the computer learns to compensate for the lean mix. |
Quote:
Quote:
You can’t take the hub off without a press. And if you press the hub out, you might as well replace your bearing, because you’re going to destroy it. The bearing is pressed into the spindle; a big ‘C’ clip is installed over the bearing; and the hub is then pressed into the bearing. The 4Runner is NOT like the Tacoma; you HAVE TO RUN THE OUTTER STUB OF THE CV AXLE. That CV nut is torqued down to (IIRC) almost 200 ft lbs, and KEEPS THE BEARING TOGETHER. The manual hub Tacoma swap has a large nut of the back of the threaded hub that holds everything together. Sent from my iPhone using Tapatalk |
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
