4th Gen T4Rs
https://www.toyota-4runner.org/4th-gen-t4rs/)
radlynx |
02-08-2020 09:26 PM |
At what mileage did you change your v6 timing chain?
I'm just curious. What's your mileage when you changed your timing chain? I'm at 150000 miles now and change my oil every 10000 miles or 1 year. So far, I've never had a problem. If you can share your experiences, I would really appreciate it. Thank you.
08TxRunner |
02-08-2020 10:20 PM |
There's no need to change your chain.
Bigshankhank |
02-08-2020 10:53 PM |
You change your oil every 10,000 miles?
Yotascape |
02-08-2020 11:02 PM |
Quote:
Originally Posted by Bigshankhank
(Post 3439280)
I was thinking the same, better off at 5k intervals
andreylights |
02-09-2020 12:23 AM |
Changed my at 125k - was having a check engine light
little_titan |
02-09-2020 12:27 AM |
Yup no need to replace your timing chain, only timing belts need to be changed.
In addition, start changing your oil every 5k-6k (if using synthetic oil) and that will prolong the life of your timing chain.
I replace my oil twice a year (5-6k). Once before winter and once before summer time.
2003-4x4runner |
02-09-2020 07:26 PM |
Im still on the original timing chain at 254k miles.
Berty_K |
02-10-2020 12:06 AM |
Hopefully I never have to do this.
Your best defense is staying on top of your oil changes. Read: Timing Chain Stretch: It Is The Oil's Fault!
10k is probably fine with a synthetic, but oil is cheap and oil changes on our v6s are easy. I change every 5k with a full synthetic.
truc.karl |
02-10-2020 03:26 AM |
I changed mine at 150k.
Bigshankhank |
02-10-2020 09:05 AM |
Quote:
Originally Posted by Yotascape
(Post 3439288)
For reference I change my oil every 5k with a synth-blend. Engine is just over 250k with nary a tick.
Timing chain is original and should outlive me. My biggest problem is I've never changed the trans fluid, but it is on my list to do a fluid exchange in the next couple weeks before spring.
techno |
02-10-2020 10:36 AM |
I replaced my chain after it stretched at 120k. The dreaded P0016.
GreatZen |
02-10-2020 02:21 PM |
I'm at 513,535 miles, and I still have the original chain. Also, not that this suddenly on oil change thread but I use Mobil 1 Extended Performance and change every 15k+.
lightfreak |
02-10-2020 06:21 PM |
I’ve had oil analysis done on various synthetics and the TBN is still quite high after 6-7K miles. The oil is still comfortably within spec and hasn’t sheared down.
10K is no problem on the V6 with any reputable brand of synthetic oil.
I think checking the level frequently and topping up is probably just as important as regular oil changes. If the chain is starving for oil it’s going to heat up and wear out faster.
I’m also on the original chain.
GJ675 |
02-10-2020 08:13 PM |
Quote:
Originally Posted by GreatZen
(Post 3440160)
That's always wonderful to hear! I hope I get many miles out of my 08 T4R. I also used MOBIL 1. I use it on my motorcycle chain instead of chain lube. Thin coat applied as needed. No wear on sprocket or chain in over 13k miles. I am hard on the throttle too! The claims Mobile 1 state are fact
newton22 |
02-10-2020 10:30 PM |
(Post 3440160)
What model year? Any other issues? Head gasket?
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
