Pj Benn's Hawaiian time maintenance and build
Howsit. New 4runner owner from the west side of Oahu. Bought my 1998 Limited 4x4 on new years day. It had 152k miles on the clock. Have been trying to get through all the maintenance and hopefully some upgrades in the future.
https://i.imgur.com/8G47dDX.jpg previous owner replaced radiator. Also has recently replaced starter, bilstein 5100's, ome 906 rears, front o2 sensor, air filter. Since I've owned it I replaced the -oil -front diff oil -transfer case oil -rear diff oil -rear axle seals -2 new tires (fronts were cupped bad from unbalance and alignment) -front brakes -spark plugs and wires https://i.imgur.com/vZbOo2G.jpg also added a remote to factory alarm system and replaced the piezo. Upcoming work -cv axles (previous owner said binside boots split 3 years ago after lift) *done -lower ball joints *done -valve cover gaskets *done -e locker sensor *wasn’t sensor. Replaced with used elocker -rear driveshaft check balance/lube -inner/outer tie rods(?) * done along with new rack -sway bar bushings -rear lower control arm bushings |
coming up tomorrow
https://i.imgur.com/yJ9bq1D.jpg tool list for job -10mm socket -19mm socket -24mm socket -35mm socket -otc 6295 front end kit -1/2in drive breaker bar, torque wrench and impact wrench -dead blow hammer -mini sledge -pry bar parts list for job -front diff fill plug washer -front diff fluid to top off -reman cv axle -new lower ball joint If i forgetting anything or theres anything that will make the job easier please let me know. I'll need to pick it up today because i hope to finish the job before sunrise tomorrow. |
Half way through and then see this
https://i.imgur.com/jo6ZWwt.jpg After paying the premium for Toyota parts and waiting over a month this hurts. Guess I learned the hard way to inspect when picking up or at the very least before installing. |
Nice rig and beautiful place to live. I lived on the north shore of Oahu years ago.
Quote:
Guess my earlier post was a little dramatic. I thought that bent shield went inside the other side and would interfere with something. It goes outside and after I bent it back seems like seals will still work fine. Hopefully can reboot old cv and it’ll be ok. Not sure how to check if it’s good enough to reboot though
https://i.imgur.com/grCXiIc.jpg Old one felt really good still. Looked ugly but no tears https://i.imgur.com/5WbxDkW.jpg Put the new one in anyway. Preventative maintenance https://i.imgur.com/T6GE38A.jpg |
Nice rig braddah! Grew up in Waianae. Hakimo rd. Family stay off waianae valley road still. Maybe I see you around next time I visit.
looks clean brah! cherry
Quote:
Quote:
Started carpeting the storage/sleeper previous owner had built
https://i.imgur.com/aG4yZ3s_d.jpg?ma...idelity=medium |
https://i.imgur.com/qNGS86a.jpg
Got a little mud on the runner on the way to and from the beach yesterday |
https://i.imgur.com/lCCkvz2.jpg
Got most of the carpet done and installed box with a couple turn buckles. Had to get it done ASAP to clear space in garage in case of shelter in place. Might add some handles for aesthetics. Still gotta do the wings and sleeper part. Deciding if I want to use different hinges and legs for those though |
Did drivers side lbj this morning. Old one felt fine still.
https://i.imgur.com/FuZ3nk9.jpg https://i.imgur.com/J8wkCbd.jpg |
Quote:
Ah ok I guess I can expect the same when I order the next one. Kinda junk because after the ‘paradise tax’ it comes out to $3xx. Considering buying from the mainland and getting it shipped here instead but not if it might get banged up worse.
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
