Aftermarket Spring Owners WITH Air Bags / Helper Bags
Curious what model kit your are running with your aftermarket (what kind) rear springs.
I had air lift helper bags (made for stock size springs) in mine when it was stock then when I tried to install them again with aftermarket - due to the increased height and width I need larger ones. Appreciate any help/responses |
Only ones I found are from toytec
4108 - Firestone Rear Airbags for use with 2-3" of Lift (03+4Runner, 07-14 FJ Cruiser, 03-09 GX470) |
We have a couple options here at Toyteclifts!
which is out of stock for a few weeks 4108 - Firestone Rear Airbags for use with 2-3" of Lift (03+4Runner, 07-14 FJ Cruiser, 03-09 GX470) these will just need to be modified a little 4135 - Firestone Rear Airbags (03+4Runner, 07-14 FJ Cruiser, 03-09 GX470) - Stock height |
Quote:
For the 4135 what needs to be modified? |
Quote:
I just installed the stock height air bags in my 4runner this weekend, I have toytec 2" taller springs. I only took two sections of the bump stop out instead of them all. Seems like a perfect fit, sorry I didn't take any pictures.
If you haven't cut the internal bump stops - just leave 1 or 2 inches more and you're good to go. Or you could buy some replacements and do the same instead of buying another airbag set.
anyone have a picture of how the bump stops and air bag should sit?
I only ask as I trimmed mine per the instructions when I was lifted (so technically i shouldnt have done as much as I did). Appreciate pics!! |
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
