Rear spring lift height - need your help, please
Hey gang,
I installed the full King 2.5 set up recently with Toytech Superflex 2.0 rear springs. Here are my post-lift measurements from hub center to bottom of wheel arch: front - 22.5" rear - 25" The issue is that the rear is too high. This is an overall 2.5" of rake at the fenders, where the factory rake is around 2". I'm not sure why the Superflex 2.0 gave me three inches of lift in the back. The fronts are exactly right - they are 2.5" over stock and I don't want to go higher as I want to retain the down travel. Need your help with advice on which rear spring should I swap shall this spring not settle much? I've read here that Icons 2.0 also give about 2.5, which would work for me. Ultimately, I want a rear spring that's a true 2 - 2.5" rather than the 3 actual I got. I usually drive empty, no rear bumper but occasionally do load up with bikes, camping gear and dogs. |
Quote:
As long as you didn't install the Superflex 2.0 HD springs, then I would just give it some time to settle. I wouldn't be surprised if they eventually settled around an inch, down to around 24''. |
Quote:
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
