2015 TRD Pro - Broke front spring? (broke while parked in garage)
Bought my 4Runner brand new in 2015. Did the recall shortly after purchasing to replace the faulty Bilstein shocks up front that would clunk in the winter, which did seem to fix it. Well today I washed by car, and dried it and parked it. Getting ready to come inside to eat, and heard a loud bang. The front left spring broke? On the lower end of the coil but not the very end. WTF? Anyone see this? The dealer did blow this apart when the car was basically new to replace the shocks and now I only have 30k miles. Oil changes only on this car have barely driven off road. Its babied. Plan on calling dealer tomorrow. Will post pics soon. These are Eibach springs right? Part #s? ugggg
I dont know if it is possible but I wonder if the spring wasn't sitting in the spring bucket correctly. There is usually a lower spot where the end of the spring nests.
Sent from my SM-N970U using Tapatalk |
Possible. Other than the fact its been like this for several years now. And broke out of the blue. Very odd and disappointing.
you might want to replace those 5 year old, corroded coilovers. Babied or not
I agree with @nb_rob on this one. Your name says it all! The rust belt has struck again. Those coilovers look 15-20 years old with all that corrosion. I agree that those both need replacing anyway. It was time for sure by the look of your pictures. You may not want to hear it, but I don't think it had anything to do with dealer fixing an issue, past problem, etc.
Fair enough. I did end up getting the underbody rustproofed from new and thankfully most of the metal underneath seems to be holding up OK where coated. Don' recall ever hearing a spring just self destruct.
Quote:
Quote:
I'd return these to the manufacturer and have them opine to the cause. |
Quote:
Unusual for sure. IMO - I'd expect at least 10 years of use from the shocks and the springs should last the life of the vehicle. Springs should not ever really sag. Some do and some are not great metallurgy. But it's unusual. The problem with unusual events is that Toyota is going to be skeptical of how it happened.
Random guess after looking closer is a manufacturing defect in the spring. I'd guess it had cracks formed over a long time and finally the metal fatigue and cracks gave way and it broke. I'd just replace with a new spring and go on. Shouldn't be very expensive. |
Quote:
nobody said all shocks need replacement after 5 years. I mean in spite of this vehicle only having 30,000 miles, they are still 5 years old, and not brand new. |
Figured I'd provide an update. Had the front shocks and springs replaced at my local dealer. They were not covered under any warranty. I've been busy with other life things so I just went ahead with the fix using factory parts. Re-aligned as well. Thanks.
Seems to me dealer should have replaced spring under warranty.......🙄
Quote:
Quote:
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
