Wiring for heated seats and diagram for power seats
4 Attachment(s)
Anyone have a wiring diagram for the Power seats on our 4th Gens?
I have a 2008 SR5 and I’m wiring some heated seat pads that I put in. It has the 30A fuses ea. For driver and passenger seats in the interior fuse box. I recall reading something a while back where someone just used the power in the same fashion. Looking for a hot wire to tap into under the seat controlled by ignition. Thought I’d found one (Green). on the multimeter but wasn’t enough power when switched on, not seeing any others. If not, what pin on the back of the ECU and color would it be that would handle another 10.6A? The kit only has a red (comes with a 7.5A inline fuse ea.) and black wire. Has a relay and is all plug and play other than power/ground. Clazzio kit with round switches. I don’t have any fuse taps and only lack wiring positive and want to get it done. I have done the full time power 12V mod for my cigarette lighters so can’t tie into that as I need to use an ignition wire. If not I can extend the wires and run to the ECU if I need to. If so can someone post a pic and what pins to tie into? Says it needs at least 5.03A running ea. Seat (seat and back) for the heaters. Clazzio Leather Seat Covers - Heated Seats Page |
The heated seat wiring from the fuse box comes in through the driver's firewall and ends there by your left foot. If you wanted to run off the factory fuse you'd need to run wiring to that point. I followed this forum to do that with my Sport Edition.
Thank you guys for your responses! I wound up using the green wire in the driver kick panel that ties into the 25A fuse into the engine compartment labeled as seat heaters. Green wire ends at the IC4 and goes no further. Did the Relay swap from the Tow to the IG to give it power and have another relay on order to fill the tow spot.
Mission accomplished! :rockon: |
1 Attachment(s)
Quote:
I noticed, what appears to be a LGreen wire there, which shows up on the wiring diagram for the seat heater. I would like to connect there, if that wire is the proper gauge, and for the seat heater. I was able to snag a pic of the center j/b before I buttoned it back up after a stereo install. (07 Sport, (cloth seats) |
Great job. I am thinking about doing the same if I can not find the limited I am searching for. Good to know there are resources available for a DIY!
1 Attachment(s)
Quote:
The green wire behind A/C does not connect to the seat heater green wire at the left foot deriver's kick panel.
1 Attachment(s)
Quote:
If my OCD kicks up, I may try to run a green wire to the junction box, as the diagram depicts. I was able to source 2 pairs of NOS aftermarket 4 gen switches, waiting on the Limited center console trim piece, and the 07 Sport to return back in town for the install. |
4 Attachment(s)
Quote:
Limited realestate and couldn’t afford 2 more spots. Considered moving one and using the dual controls switch for 1 spot from Clazzio but decided to just use the small circular switches and use some free realestate. Looking at the rectangular Toyota switches from Clazzio now I don’t think it would fit proper into the console, possibly fit into one of the 2 dash spots with squared up corners? Unfortunately I seem to run out of switch locations too fast and have 3 more currently I need to make room for that are hidden at kick panel. |
This thread has been so helpful, thank you
3 Attachment(s)
** Enter at your own Risk!!
{UNPLUG BATTERY Ground - wait 15+ mins., surf T4R.org} The Seat Warmer Green Wire.... :whip: Ends at the IC4 connector as mentioned by others... :high5: ---> To add a female pin to the connector. The IC4 connector consist of FOUR separate connectors, connected together. IC4 needs to be unplugged, the specific connector unlocked, and removed from the cluster. Once the connector is removed you can get to the lock on the connector to install the female pin. {The blue, yellow, and gray connectors were removed to get to IC4} Thanks to the T4R folks for the motivation.. :rockon: |
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
