5th gen T4Rs
https://www.toyota-4runner.org/5th-gen-t4rs/)
graeaglecrawler |
01-16-2021 01:24 PM |
How to re-torque the 19 valve body assembly bolts on the transmission
Has anybody seen a write up on this? I've done some searching bot could not find anything. Looking for sequence , torque etc. Thanks
fkheath |
01-16-2021 01:58 PM |
Quote:
Originally Posted by graeaglecrawler
(Post 3592493)
Try the factory repair manual : TOYOTA 2016-2019 4Runner Repair Manual RM27F0U
Nobody Special |
01-16-2021 02:35 PM |
(Post 3592493)
Just curious...
Valve body mod?
graeaglecrawler |
01-16-2021 03:15 PM |
I'm just changing the fluid in the transmission and came across in a search that you should re-torque the bolts before reinstalling the filter. It mentioned the valve body gasket shrinking over time , then the bolts loosen and fluid can escape to other parts of the valve body instead of where it is supposed to go.
graeaglecrawler |
01-17-2021 02:30 PM |
I'm answering my own question =). I found the info on youtube in an IPT Performance transmission video on replacing the valve body on an A750F tranny, about 10 mins. into the video. Torque 80 in/lbs. No torque sequence mentioned. There are two bolts obscured by a bracket.
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
