Toyota 4Runner Forum - Largest 4Runner Forum
Toyota 4Runner Forum - Largest 4Runner Forum (https://www.toyota-4runner.org/)
-   5th gen T4Rs (https://www.toyota-4runner.org/5th-gen-t4rs/)
-   -   I made my own hitch mount spare tire carrier. (https://www.toyota-4runner.org/5th-gen-t4rs/294432-i-made-my-own-hitch-mount-spare-tire-carrier.html)
ctnewman 01-29-2021 11:48 AM
I've been sniffing around trying to get a spare tire carrier for my 4 runner. I think the Detours of Maine one is the nicest available, but I thought I could make mine fit a little bit better and also be a little cleaner looking.
*******************EDIT*******************
I was thinking about making FIVE more of these total. One is already spoken for. If you'd be interested, shoot me a DM.
In addition to my original design with the tight fitting installation, they would have a few new features like:
1) camera mount in the center of the wheel
2) higher mounted license plate
3) wiring tie tabs
4) secondary latch system which holds gate in "open" position
5) 2 stage wrinkle black powdercoating
6) stainless steel contact areas in places where the powdercoat could get damaged.
It could be available either centered or offset. I'd be interested to hear if the general desire would be for centered or offset design.
There are some things I'd change if I did it again, though. I was just sort of winging it as I went. Usually I spend more time on the "planning" stage.
Here's a finished shot:
https://i.imgur.com/hAFEqA4.jpg
Here's how it went down.
First I bought an amazon hitch extender for like 20 bucks.
Then I cut and beveled some 2x4x1/4 wall rectangular tube:
https://i.imgur.com/HdoiYEK.jpg
Tacked them together:
https://i.imgur.com/C3IIyGf.jpg?2
Then finish welded, and chucked them in the mill and cut the ends to accept the pivot. Doing this after welding allowed me to ensure my arms would be perfectly parallel.
https://i.imgur.com/cVp6v6I.jpg
Then I turned a pivot shaft from some solid 2" round. I used 1.375 as diameter of pivot pin:
https://i.imgur.com/5Ukjb74.jpg
Next I welded on some tube to the end of the upper arm, then put it in the mill and bored it to eliminate any distortion from welding.
This is my second MIG welding project so don't judge my welds too harshly.
https://i.imgur.com/91lJFHN.jpg
I didn't have any appropriate bushings laying around but I did have some Bronze and a lathe:
https://i.imgur.com/qrmSFn5.jpg
These pressed in nicely. Please ignore horrible welds.
https://i.imgur.com/z0ZBoJE.jpg
Next I pulled my bumper cover, unbolted my receiver, and welded two tabs to it. There are a lot of different ways these hitch carriers lock on, but for me this was the easiest.
https://i.imgur.com/ae1zzh1.jpg
Next I started mocking things up on the truck:
https://i.imgur.com/2e9hFnN.jpg
One of the key things I wanted to do was keep the bars really tight to the bumper. Aftermarket ones to me all looked like farm equipment.
https://i.imgur.com/aHHSmHr.jpg
No pictures, but I machined a small block to bolt the locking clamp to. There is a bracket that hangs off the upper arm. This supports the wheel when it's closed and doubles as a tab for my clamp to lock down. It rests on a striker plate I welded to the lower arm. Both these parts are made from stainless steel because eventually the powdercoat will rub off. I also added a license plate holder and some stoppers to keep it from opening too far.
Here's a crappy shot of everything after it was all welded
https://i.imgur.com/qscLrDE.jpg
Then I powdercoated it and it was ready to use. It's ROCK solid and functions exactly how I expected it to. Here are some more finished pics.
One of the things I wanted was for it to be offset (for future ladder placement) and as close to the hatch as reasonably possible.
https://i.imgur.com/umcoUNF.jpg
https://i.imgur.com/5iVhCT9.jpg
https://i.imgur.com/sYbnBnK.jpg
So what would I change? A couple things:
1) Less offset. I think I could have moved the wheel about 3" to the left. I think it would just look a bit better aesthetically.
2) shorten the receiver a bit. This was just me being lazy. It will hurt departure angle.
3) make the bottom tube about 2" longer so I could have put my plate higher. It was either going to hang off the end of the tube or hang below. It's on a sturdy bracket but we will see if it snags on stuff on the trail. It doesn't hang lower than the hitch, though.
All said and done, not a bad way to spend a weekend and 100 bucks.
Ryance39 01-29-2021 11:59 AM
That's pretty slick and looks good. Wish I had the skills to fab something like that up.
daytonaviolet 01-29-2021 12:06 PM
Looks great. When can you make the changes and send one to me :-)
NotaTRD 01-29-2021 12:10 PM
Looks good.
Do you have any weight estimates and how much time would you say you invested into this project from start to finish?
EDIT****
I missed the part where you said you did it over a weekend.
ctnewman 01-29-2021 12:15 PM
Quote:
Originally Posted by NotaTRD (Post 3597621)
Looks good.
EDIT****
It weighs around 60LB plus wheel.
Saker 01-29-2021 12:34 PM
4) Back up camera kit in center of tire carrier (like the FJ’s have/had).
5) No offset option (center of rear hatch)
:becky:
uh0h50 01-29-2021 12:37 PM
Oh man, it looks killer. Shoot me a price shipped to CA unpainted.
Saker 01-29-2021 12:37 PM
BTW, I like it a lot
spartacus 01-29-2021 01:03 PM
Great job. Any one can buy it of the shelf products and bolt on, so its always good to see creative, talented people making functional stuff.
BobWheelerJr 01-29-2021 01:45 PM
So,
(1) I love the fact that you still have a functional hitch. Most of them I've looked at don't. I have to have a functional trailer hitch.
(2) How hard was it to move the camera?
(3) If you had a ladder on the driver's side (I do) would this interfere with that?
and lastly... what would you charge a brother for this rig, assuming you decided to make a vocation out of your hobby?
ctnewman 01-29-2021 02:14 PM
Quote:
Originally Posted by BobWheelerJr (Post 3597672)
So,
1) Thanks. I felt similarly a lot of them have a 2" receiver but I don't think they can actually be used for towing.
2) I got an Aiden James Customs camera relocation kit. It's 125 bucks and takes about 60 minutes to install.
3) I keep thinking about that. I don't think there is any practical way for me to mass produce these. I'd have to charge more than anyone would pay, probably.
Charlievee 01-29-2021 02:26 PM
Best i have seen to date.
John in NC 01-29-2021 02:27 PM
Wow! Skills! Only thing I'd want is for the spare to be lower to increase visibility out the back window, but I'm sure there's a reason it's located where it is.
Great job.
Saker 01-29-2021 02:30 PM
So structurally, you cannot tow with this one ?
ctnewman 01-29-2021 02:35 PM
Quote:
Mine? Definitely can tow with it. The tongue weight of the trailer will be reduced a bit, though.
A) because of the weight of the unit itself
B) because of increased moment because the hitch ball is further out.
On other "off the shelf" tire carriers there is a 2" receiver but it doesn't look stout. It looks like it's more for other "hitch mount" accessories.
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
