2004 white SR5 Sport 4wd/V8- Ripon WI 240k $4700
2004 T4R sport edition
White Hood scoop 4wd & V8 240k Timing belt and WP done at time of purchase with previous owner at 222,222 Has Scan Gauge II Non smoker Maintenance since ownership: 222,222 Timing belt and WP Denso 3297 plugs (8) Htp cabin air filter Phillips low beam bulbs Phillips high beam bulbs Phillips fog light bulbs Power stop k2422 drilled and slotted rotors all 4 corners Power stop brake pads all 4 corners Rear diff fluid changed Front diff fluid changed Brake fluid flush Brake fluid reservoir replaced Power steering fluid flushed Duralast MAF sensor replaced (will provide my phone number for the lifetime warranty) Washed with griot's garage/clay bared and waxed HCF delete Oil changed with mobil 1 oil and mobil 1 filter every 3500 miles. Dash is has cracks in the material that's covering it, no crack goes through the dash. Currently has a removable carpet cover on it. Needs a new exhaust 02 sensors/exhaust. Gets check engine light for p0175, P0171. Currently rear hatch lock is frozen. Will disassemble and lube once it isn't -4 degrees out 4700 and I'll get it detailed before you pick it up or 4500 as is. (Just dirt/light pet hair) Will run through the touchless carwash and upload pics |
Please request pics. I cant upload
Please request pictures I cannot upload them to the original post
If your frame is not destroyed by rust you should be able to move this. Post some frame shots for those who might be interested.
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
