Fs: eastern wa 4Runner stuff - Rigid hitch tire carrier, k9 Maxtrax bracket, Ram mnt
I’d like to just sell face to face - especially for the tire carrier which will be too heavy to ship cheaply. Tri cities area of eastern wa.
Pics: Imgur: The magic of the Internet ——————————————————— K9 EEZI-AWN MAXTRAX MOUNT SET (2) $40 This is JUST the 2 mounting brackets - no maxtrax mounting pins (those are sold separately) or Maxtrax boards. You should be able to use these to mount to any roof rack type or a multitude of surfaces. The MAXTRAX Mount is an ingenious way to mount 2 or 4 individual MAXTRAX to the side or the top of your K9 Roof Rack System. Designed to be used with the MAXTRAX Mounting Pin Set, which are high-quality black nylon and stainless steel quick-release pins (not included). The hole in the top of each pin is compatible with a TSA-style padlock. The mount has a flat back surface, and utilizes one of the included K9 Accessory Adapters to attach to the top of the rack. Set includes (2) mounts. ——————————————————— RAM Pod I Locking Vehicle Mount with 18" Rod and Socket Arm $20 RAM Pod I Locking Vehicle Mount with 18" Rod and Socket Arm Sturdy way to mount a tablet, phone, gps, or other device in your rig. Solid aluminum rod inside. Uses the bolt of the front seat and can be bent for proper orientation. If you happen to have a 5th gen 4Runner this is bent perfectly to be the most stable with minimal movement. ——————————————————— Rigid Armor Toyota 4runner (1998-2020) Spare Tire Hitch Carrier $350 Brand new and never installed. Was waiting to buy a set of new tires and wheels before I mounted this. Going a different direction now. This carrier will now be released with a additional 2” hitch insert, in order to not loosen up the stock hitch. It carries a wobble free hitch insert and a 2-locking mechanism on the swing arm. Drop down at 45 Degrees 2” Spare hitch 2000 lbs. rated toggle latch .5 quick release pull-out pin Hitch insert wobble free lock Made from 8120 1/8 square tube Weighs 35lbs Max tire size 34” Holds 100 lbs. arm strength Works best with a oem 4 1/2” standard hitch or bigger |
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
