SOLD FS: 3rd GEN, 5 SPEED, E-LOCKED- $14K LOS ANGELES
8 Attachment(s)
I’m selling my 1997 4runner, 4x4 and is e-locked. Clean title, with a JDM engine that I put in 4 years ago that currently has about 120-130k miles. Car has a ton of mods and is ready to go. I built this 4runner knowing that I would never sell it. I trust this car to take me anywhere and bring me back with no issues whatsoever. If I had to drive it across the country right now, I would not have a problem doing so.
Reason for selling is it because a got a newer car and don’t have the space to keep this one. All the maintenance, specs and info are listed below. I’m sure I forgot to list a couple of mods too. Miscellaneous Outgearsolutions roof rack LCE stage 2 clutch Marlin Crawler steel braided clutch line Tundra brake upgrade with Akebono pads (literally stops on a dime) Dash cams front and rear with security (if someone walks around the car or the car gets hit, it’ll automatically record) Whiteline bushings for LCA Black widow race venom exhaust with custom high clearance tailpipe Snorkel with prefilter (fully sealed) AirAid intake tube Hilift jack 2 Jerry cans CB radio antenna mount Red Firestik with spring mount Coax wired to center console from Firestik RAD rubber designs engine splash guards Have fittings mounted on front and rear bumper ready for on board air & 2.5 gallon Viair tank mounted below rear of vehicle Andranik ditch light brackets Retrofit headlights with LED’s LED reverse lights Interior HURST short shifter (THE BEST THING EVER) T-Case shifter knob to match the HURST Custom Sleeping platform with drawers All doors, trunk and roof are sound deadened (huge difference from stock) Outbound Nevada molle panel (limited edition with the 3g4rsocal logo) 99+ steering wheel swap Center console upgrade with cup holders Prewired for CB radio Husky liners floor mats Single head unit Led interior lights Led gauges/ac control Kill switch (hidden will show buyer where it is after everything is finalized) Cooling Koyorad aluminum radiator SPAL 12” 1640 CFM pusher fan I used to run Stant 170° thermostat but the car ran too cool with it (160° in the snow and 165° in the winter) currently running an OEM thermostat and the hottest I’ve ever seen it get is 197° going up a steep grade for a constant 5-10 mins while it was 115° outside. In other words this thing is almost guaranteed to never overheat Electronics Optima group 31 battery CBI group 31 battery tray Big 3 upgrade GP heavy duty battery terminals Cs144 alternator with connector Scarab hood light Switchpro (connects all lights) Roof rack with lights all around PIAA lights on roof rack in front PIAA chase light on roof rack in rear Rock lights Element LED amber canons ditch light Element LED amber cannons on bumper Smittybilt 9.5k winch Wheels & Tire FN 5 star wheels, 8” wide, -25mm offset 5 Falken AT3W 285/75r16 (have 2k miles only) Full size spare with matching wheel Spidertrax 1.25” hub centric wheel spacers all around Front suspension Total chaos UCA (fully serviced 2k miles ago new FK uniball & bushings) Bilstein 6112 for a Tundra (stiffer valving) Eibach 700lb coils Wheelers off road superbumps Rear suspension Outboard shock setup from envision fabrications Bilstein 7100 shocks Old man emu 851 coils Wheelers off road superbumps Rokmen upper links (rear adjustable) Rokmen pro lower links (rear adjustable) Rokmen panhard bar (adjustable) New FK heims for Rokmen upper links & panhard Toytec panhard drop bracket Armor ARB front bumper Savage off road sliders Shrockworks rear bumper with swingout & dual jerry can mount Fender bars that connect from front bumper, sliders, and rear bumper custom made by Mayhem Metal Works Skid plates Savage skids full set Lil skip off road gas tank skid Bud built diff skid Lotus rear link mount skid Eimkeith LCA reinforcements McKenzie limit straps with adjustable clevis Eimkeith strut tower reinforcement Eimkeith upper link reinforcement Total chaos Upper Coil Bucket Tower Gussets Maintenance ALL PARTS USED ARE OEM MAF SENSOR AND THROTTLE BODY ARE CLEANED EVERY 10K MILES Bought April 19 2016 Bought w 291,610 miles Done lower ball joints and maintenance at 292,000 miles Spartan Locker 299,219 Diffs, T-case and trans fluid changed at 316K JDM engine 298,840 Fuel Filter changed at 315,500 New injectors & Fuel pump at 316,600 Hankooks at 317,500 Whiteline LCA bushings 320,500 Rack and pinion, inner & outer tie rods 321,100 New Coolant after full flush (12 times) 323,450 New belts at 323,450 Front brake pads 325K New Bilstein 6112 328K New 700lb springs 332k New LBJ’s and bolts 332K New spindle bearing (driver side) 332K Spindle gussets 332K Rear axle seals and bearing (pass side) 334K Front diff and T-case fluid change 336K New radiator cap 337K New fan clutch 337K New 170° T-stat 337K Coolant flush and new coolant 337K New plugs 340K Koyorad aluminum radiator 341K (July 9, 2019) New coolant 341K New passenger side inner tie rod 342K Alignment at 342K (July 29, 2019) Alternator 343K (August 5, 2019) Rear diff fluid (85W-140) 343K 4.30 E-locker rear axle and front diff 345K New rear seals and bearings 345k CS144 alternator 346K New OEM timing belt 346K New coolant 346K Transmission mount at 347K (Nov 22, 2019) Rear diff fluid 347K New OEM 180° t-stat and coolant 348K Rack & Pinion bushings 353K OEM LBJ 353K (Apr 4, 2020) Moog tie rods 353K (Apr 4, 2020) New PCV & grommet 354K Throttle body & MAF clean 354K Optima battery 362K New rear shocks (outboard shock) 362K Throttle cable 362K Heater core valve 362K (Oct 8, 2020) Falkens AT3W 362K (Oct 13, 2020) Upper link heims 362K New clutch (LCE stage 2) 362K New clutch master and slave cyl 362K New stainless clutch line 362K New low switch and recharge 362K (A/C) New OEM u-joint 363K New plugs 363K New NGK wires 363K New Denso coils 363K Trans fluid (MT-90) 363K UCA bushings & Uniballs 364K (Nov 15, 2020) Rear diff fluid 364K Used OEM PS pump and in line filter 365K Power steering and new hose 365K Exhaust tail & new cat 365K Coolant flush 365K New radiator hoses 365K Clutch pedal rebuild 365K Front diff bushing (Durobumps) 365K New coolant reservoir 365K Asking $14000. Pink slip in hand. Call or text me at: 7one4 7eight7 7six8two |
5 Attachment(s)
Some more photos
Sold
Sold sold sold!!
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
