Front shocks and springs options for 1.5" and 600ish lb/in?
I've currently got Toytec coilovers and 550lb springs set to roughly 1.5" of lift, but both front shocks are leaking.
I've added a plate bumper and winch, so I need stiffer coils. Seems like anything Bilstein 5100 w/ OME coils is going to net me 2.5-3", which I want to avoid because my CVs vibrate like crazy above 1.5" at highway speeds. What are my options besides threaded body coilovers? As I understand it 6112s are adjustable with the 600lb but that's getting into coilover money. Any other options? |
Quote:
Dobinsons 2.0" Lift kit Dobinson 2.inch lift kit vs Ome lift kit |
I myself am leaning toward the dobinson 2 inch lift with the 134 and 137 springs as a kit, and the fronts assemebled.. Need heavier in the front for my arb and winch.
My last lift was 3 inch with billies and had no complaints . The lift b4 that was using 99 talls and KYB's ( b4 arb and winch) that gives you one inch and no need for diff drop or panhard correction. However in 2 years my rear kyb's were leaking....but it got pretty heavy use. with the one inch I could run the 265/75/16 on stock rims with no issues on light off road. My current ride is so shot, ( just bought a few months ago) it wont fit even 70 series without rubbing so need to do something soon. Vibration, you can put in a diff drop, which drops the diff about 1 inch and gets rid of that vibration and the extra wear on the cv's on 3 inch lifts. I will prob do the diff drop and the pan hard correction brackets with this new lift, even though im only going 2 inches. EK originally designed the panhard brackets for his 2 inch lift if I remeber correctly. Ordering The dobson kits are so popular that they keep running out of them, so check on it, but dont be in a hurry. Same happens iwth the billies. |
Quote:
I'll have to do some more digging on Dobinson's stuff. I want monotube shocks, but there's not a whole lot of info out there about their IMS line. That brand seems like it's really started to get popular over here in the last year or two though. |
I did a manual hub swap. Best thing for the vibration. Found a full set (spindles, hubs, and cv's) with 150k miles on them for $400. Took about an hour per side to swap out. Huge difference. Diff drops do nothing IMO.
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
