Front Lower Control Arm bolts won't stay torqued
Alright, this is driving me insane. I've had like 3 alignments this year, and none of them hold for more than 5 miles or so. :tsk:
As far as I am aware, the front lower control arm cam bolts just keep coming loose. As soon as they do everything starts creaking and popping and the alignment blows up. I'm running the whiteline bushings, I've no idea if these are the issue but I've no idea what else would cause it. One thing I noticed though is that...well, how exactly does one torque the rear camber bolts? (Rear position on the front LCA's). None of my torque wenches can fit into that spot due to the power steering rack being in the way. This got me to thinking...what if none of the shops I've been to have a way to torque it? I guess the only way one could do it would be to use a crows foot? Maybe they are just doing it hand tight, which would explain why they don't last long. Has anyone else experienced this problem? Really running out of ideas here, I feel like the arms are going to fall off at some point... :censored: |
I have not done my lower control arm bushings yet but I did get the same bushings just waiting for a weekend to do it. I used to be alignment tech and we never used to use a torque wrench on suspension stuff while doing an alignment. However with those bolts I would go as tight as possible and then some! Maybe even a hammer at the end of your wrench just to get some more turn on it. Usually when they tighten them the suspension is drooped so maybe tighten them more when it is on the ground. Also, I remember I had a comeback one time on a Dodge Durango. Anyways, going as tight as I could with my wrenches on the UCA wasn’t good enough and the alignment came loose. Using my big 1/2 snap on ratchet solved that issue! I guess what I’m trying to say is that tight is tight and maybe OEM torque specs are not tight enough for some things.
Quote:
Code:
https://www.toyota-4runner.org/3rd-gen-t4rs/217550-3rd-gen-t4r-diy-maintenance-repair-modification-videos.html |
Quote:
For the back ones I’m sure they use a box wrench or adjustable and crank the shhhhh out if it. Seems like an odd issue man. Hard for me to think how the white line bushings could be to blame. I’m gonna have to ponder. |
locktite?
Quote:
Quote:
I actually found a 22 mm 1/2 drive Crow's foot, it's from snap-on. I'm probably going to order it and see if it works. Quote:
Quote:
Quote:
96 is about the torque on lug nuts. Sent from my iPhone using Tapatalk |
Cam bolt elimination kit with after maket ucas could also be an option.
Quote:
Okay so I did finally find a 22mm 1/2 drive crows foot. I'm going to order it and torque the bolts to 96 ft lbs just to see if the noise stops. If that does the trick then the next time I get in an aligjment I'm just going to bring it and either tell him to do it or let me do it as soon as they're done... Haha Speaking of that, is it worth it to get a torque wrench calibrated or just to get another one? I don't have an expensive one so that's why I'm not sure if it's worth it or not.. |
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
