Group 31 Battery Box + R4T Group 31 Battery Terminal
2 Attachment(s)
In the past, swapping the factory battery to the 31 Battery was a huge headache simply because of the lack of available wiring on the factory harness. You'd find yourself shrieking with frustration saying "It's not reaching the terminals!" 😫
Well, shriek no more 'cause here's the solution. This known problem is easily solved with the R4T Battery Terminal upgrade. This terminal will allow the you to retain the factory connections without extending the wires or adding an unprotected terminal block. Easy installation of the factory terminals Fully insulated terminal blocks to prevent shorts Multiple terminal locations for accessories such as winches, switch pros, and many others that require direct connection to the battery Clean look while adding versatility Throw in our Stainless Steel Group 31 Battery Box not only for a rust free guarantee but to also ensure your battery is safely secured. Rocky uneven terrain tested and proven to keep your Odyssey battery safe no matter what road you travel. The battery you're going to want for this set up is the Odyssey Extreme Battery Series Group 31 Battery. Odyssey builds their batteries to outlast the competitors and the power to take you from start to finish no matter what you're running. *Battery sold separately *R4T Group 31 Battery Terminal is drop shipped from R4T. |
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
