Intermittent Cooling leaks on 4.7 - Pressure test
I have an occasional coolant leak on my 04 4.7 I lose almost a 1/2 gallon per 1000 miles. The engine has never overheated.
It looks to be coming from behind the engine. I have found other threads that suggest the water pump or an o-ring on the tube above. They leak sending coolant to the back of the engine from on top of the engine. I have seen it dripping from behind once or twice. It will drop a pint of coolant on the ground fairly quickly but now that I have pulled my skid plates I can not recreate it to confirm. Would a pressure test show me the leak? I'm not sure how it would be different than just running the vehicle to operating temperature? |
Quote:
If you're able to try a UV light let us know if the coolant does indeed glow. |
Quote:
Amazon.com: MASTERCOOL 53351-B Professional UV Leak Detector Kit with 50W Mini Light, Black: Automotive Buckaroo |
kit ordered
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
