5th Gen Toyota 4Runner Lower Control Arm Skid
2 Attachment(s)
Gain the protection you need while out on the trails with the Rago Fabrication Lower Control Arm Skid. Our 3/16" P/O steel is laser cut for the perfect fit on your 5th Gen 4Runner. Our design has a fully welded front plate that layers the main body for extra strength. The front edge design is engineered to conquer the toughest terrains while the back is designed to prevent you from getting stuck while rolling backwards.
*Please check your clearance of the backspace for your rims prior to purchase. If you have an offset then you will need to make sure you will have clearance between the LCA Skid and your wheel/tires. We have 17" Rims with a -10 Offset and clearance of roughly 1 inch at full rotation for an idea of what you will need for your vehicle. The Details Made in the USA Easy 20 minute install NOT COMPATIBLE WITH ALL TRD/ TRD PRO MODELS, FACTORY SKID PLATE or KDSS Kick-out for additional protection Laser Cut and CNC Bent 3/16" Cold Rolled Steel Raw Steel or Powder Coated Textured Black Options All hardware included No Drilling Required Read more about this product on our Lower Control Arm blog. Have a Factory Skid Plate? Check out the TRD Pro Lower Control Arms. The TRD Pro Version is designed for factory skid plates whether they are TRD's, TRD Pro, Sport or other Factory Skids. 4Runner | Lower Control Arm Skid | 5th Gen – Rago Fabrication |
Could you PM me a price for these shipped for a 2021 4Runner w/ KDSS? Thank you!
Quote:
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
