Toyota 4Runner Forum - Largest 4Runner Forum
Toyota 4Runner Forum - Largest 4Runner Forum (https://www.toyota-4runner.org/)
-   3rd gen T4Rs (https://www.toyota-4runner.org/3rd-gen-t4rs/)
-   -   Shocks for my 97 4 banger (https://www.toyota-4runner.org/3rd-gen-t4rs/297334-shocks-my-97-4-banger.html)
Biogenic 05-12-2021 10:49 PM
What do you guys recommend for my 4Runner ? I go off road very rarely. 2wd sporting 235/75/15 tires 203k
I can feel pretty much every pothole I encounter [emoji3061]
cas5259 05-12-2021 11:30 PM
I just installed KYB gas-a-just and am happy. Stock height, comfortable and not too stiff.
JZiggy 05-12-2021 11:54 PM
If your springs are sagging you may also be hitting the rear bump stops. So check on springs too and not just shocks.
zanderale 05-13-2021 06:48 AM
Gabriel coil overs for the front, KYB for the back and new springs. Replaced all sway bar and rack bushings too, and it rides like a dream! Total cost for everything (RockAuto) was $350. Last month I got new tires (Cooper Discoverer AT3) and those significantly improved my ride as well. ‘97 2WD SR5.
cl4Rk 05-13-2021 08:59 AM
Like @JZiggy said, check both springs and shocks.
I’d also consider all your suspension-related bushings and bump stops. All that rubber is old and likely dry and hardened, if not cracked or ripped up.
rglsr 05-13-2021 09:52 AM
I run KYB Gas Adjust on my 3RZ 4Runner, primarily street driven, I prefer the firmer ride on pavement. Definitely improves handling. From your comment on potholes you may want something not so stiff. Agree on the other suspension components suggestions, tires can also make a difference on ride quality.
Biogenic 05-14-2021 12:10 AM
Thanks all. I’ll definitely check all the things you mentioned.
Copyright ©2000 - 2026, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2026 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2026 DragonByte Technologies Ltd.
