Will these tires+wheels fit? Help me with offset and tire size math
Username says what I drive. All stock thus far. Thinking of adding these wheels:
4PLAY(R) 4P60 Wheels - Black with Brushed Face Rims In a 22x10, -18 offset, 6x139.7 bolt pattern, 106mm hub. I wish to mount a 285/45R22 tire on these. Curious if backspacing alone is enough to clear without modifying suspension. (I have X-REAS) Stock: 245/60R20 = 31.6”x9.6” Install: 285/45R22 = 32.1”x11.2” (this is an EXTREMELY low profile A/T tire, only found Nitto Terra Grapplers in this size, no BFG) Will this setup clear stock height without trimming? I didn’t find this (specific) size in the cheat sheet with the green/yellow/red for all the tire sizes and if they clear. Sent from my iPhone using Tapatalk |
Well, the vehicle fitment for a 2021 4runner 4x4 says that wheel does not fit your vehicle. Your proposed tire is 2" wider than stock, that's a lot. How is your current clearance to UCA? You will no doubt need to push that tire to the outside but then you probably will have rubbing on the front/rear of wheel well when turning. So you have a fun project ahead of you.
There are wheel fitment charts you can google and put in your current wheel/tire setup and your proposed and it will show you what will happen. I would use that before any major wheel/tire changes. |
you're buying 22's for a 4runner. who the f*ck cares if they fit. sell the 4runner and buy an escalade.
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
