FS, 1999 SR5, Clean w/ 5spd and e-locker, Overland Build, Grand Rapids, MI - $11k OBO
2 Attachment(s)
**SOLD**
**MORE PICS AVAILABLE ON REQUEST** The day I never thought would come has arrived. I’m putting my beloved 1999 up for sale. I’m still in the T4R game though. A 5th gen just fits my family of 5 a little better. So here she is. 1999 SR5 w/ 5 speed manual and factory e-locker in Desert Dune Metallic. I’m the third owner and it has 147,000 miles on it. The truck is in extremely good shape - inside and out. It runs and drives perfectly. I’ve meticulously cleaned and maintained it. There is no rust on the body, and very minor surface rust on the frame/underbody. Having been in Michigan since 2013 (when the second owner brought it from Arizona), it is in amazing shape underneath. The previous owner immediately started treating it with Fluid Film and I have kept that up since I’ve had it. In case you don’t know Fluid Film, the way it works is it forms a non-hardening coating and when dust naturally clings to it, it forms what I like to call a “grime barrier” that keeps the rust at bay. So looking underneath it’s dirty, but there is only minor surface rust here and there. The steel rear bumper is past due for a sandblast and new powdercoat so that has some surface rust since it didn’t get Fluid Film quite so much. The original interior and upholstery is in very good condition, but to further protect it, it has a full set of fitted Wet Okole seat covers that are a waterproof neoprene. Here’s a notable list of updates and modifications
Ever since being bought by the second owner, a detailed maintenance log has been kept for this truck. Noteworthy Maintenance 08-21-13 87175 Oil Change 08-21-13 87175 Engine Air Filter 08-21-13 87175 Timing Belt 08-21-13 87175 Accessory & AC Belts 08-21-13 87175 Clutch Assembly & Throwout Bearing 08-21-13 87175 Re-surface Flywheel 10-15-13 89550 Re-Paint hood & roof 11-08-13 89800 Rear Hatch Lift Struts 11-10-13 90000 Wiper Blades 04-05-14 90959 Oil change 09-01-14 91623 Rear Wiper Blade 09-18-14 94700 Trans & transfer case fluid change 11-19-14 95555 Oil Change 11-19-14 95555 Replaced Clutch Pedal Clevis/Pin 12-28-14 96008 Front & Rear Diff Fluid Change 01-05-15 96012 Tundra Brake Upgrade 01-05-15 96012 Braided SS Brake lines 11-15-15 99789 Oil & Filter Change 12-30-15 100538 Lower Ball Joints Replaced 12-30-15 100538 Front Sway Bar End Links 12-30-15 100538 Clutch Pedal Bracket Replacement 12-30-15 100538 Headlight Bulbs 12-30-15 100538 Rebuilt/Re-sealed headlights 07-22-16 106000 Oil Change 09-03-16 106600 F/R Diff/Trans/XferFluid Change 11-20-17 112500 Steering Rack Bushings 11-20-17 112500 Driveshaft rear u-joint rebuild 11-20-17 112500 Oil & Filter change 12-15-18 116500 Accessory & AC Belts 12-15-18 116500 Lower Control Arm Bushings 12-15-18 116500 Steering Rack, inner & outer tie rods 6/1/2019 118000 Battery 6/1/2019 118000 Front Upper Ball Joints ----------- Change of owner 7/30/2019 123145 Oil Change 1/2/2020 131680 Oil Change 5/4/2020 135899 Coilovers and UCA clean, grease, and pressure check; F/R Diff fluid; Rear Diff breather extension installed 5/8/2020 136000 Replaced L+R full headlight assemblies with factory originals (salvage donor); This was due to failure of the seals done by previous owner 5/29/2020 136000 Rebooted L+R CV axles and replaced L+R axle/diff oil seals; Front diff fluid changed 9/4/2020 13?000 Rear Sway Bar End Links 10/20/2020 141211 Valve Cover gaskets, Throttle Body gasket, Intake Plenum gaskets 10/23/2020 141211 Oil Change This truck has been used like a 4Runner is intended, but not abused as you can tell. Here is a short list of things I would want to know if I was buying it.
Hi, I'm interested. Can I text you?
Quote:
Truck is pending sale
Quote:
Closing this chapter as a new one starts. I'm happy to say I've sold this to another forum member. Looking forward to seeing it continue to be a part of the community.
Quote:
Hi, I'm the new owner - based in Laguna Beach, CA :) |
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
