Is there an full inspection guide for 4Runner?
Guys, I have 2010 4runner limited. Thanks to all my friends here I stop hopping by dealers since 2015 and did all required maintenance myself. My T4R is so far running well.
Now I'm planning my first road trip since the pandemic. I will put about 5000km on my T4R for this trip. I am wondering if there is a full inspection checklist or tech guide that can walk me through everything so I can be on the road confidently. |
You can check on the Toyota Canada website for the Maintenance Schedule.
Maintenance Schedule - Toyota Canada Simply by the age of your vehicle, you could be looking at the following: At 114 months: Oil & Filter Service - Replace engine oil & filter. Remove & inspect air filter element. Lubricate locks, latches & hinges. Inspect lights, horn & wipers for proper function. Inspect coolant, brake & washer fluid levels. Inspect tires & adjust pressure as required, including spare. At 120 months: Replace Super Long Life Coolant; Tighten Propeller Shaft Bolts; Lubricate Propeller Shaft; Brake Service;, Replace Cabin Air Filter; Replace engine oil & filter. Remove & inspect engine air filter element. Lubricate locks, latches, & hinges. Confirm lights, horn & wipers function properly. Check coolant, brake, transmission & washer fluid levels. Perform battery service and comprehensive electrical charging system evaluation. Inspect valve clearance (audibly). Inspect drive belts for damage, adjust tension if required. Check steering gear box, linkage and shock absorbers for looseness, damage or leakage. Inspect ball joints and dust covers, driveshaft and steering rack boots, chassis nuts & bolts for looseness or damage. Remove wheel and brake drum, check pad/shoe thickness. Examine brake calipers, wheel cylinders and brake lines. Inspect fuel and exhaust systems for leaks or damage. Examine tires for damage and wear, check & adjust pressure (rotate if required, additional charge). |
Quote:
In the past I have used the certified pre-owned inspection checklist for pre-trip prep |
I always wonder about these " Tighten Propeller Shaft Bolts". Checked many times, I didn't see any possible why these bolts got loose. ��
The guide is to visually look and inspect everything and act accordingly.
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
