Aftermarket wheel sizing and spacing question
I have a Nightshade with factory 20’s. The constraints of my question are that I am asking it WITHOUT assuming BMC, trimming, lift, or level will be involved.
I want to see if deviating from factory wheel width or offset can help me accommodate any larger tire, without rubbing, than a factory wheel can. Example. I have my eyes on a 275/55R20. I know that Discount Tire (America’s Tire) will let me squeak by despite the rim with of 7” falls outside the lower bounds of the rim width range for that tire size (7.5”). If I play with wheel size and offset ONLY, is there any chance at being able to clear anything larger, or is “every deviation is a bad deviation” that will bring me closer to, not farther from, hitting the nearest wheel well liner or suspension component? This has a little bit more detail than the popular T4R tire fitment spreadsheet shows, with green/yellow/red. It’s useful, but I want to get a little more granular than that with this question. TIA! Sent from my iPhone using Tapatalk |
No. Even 275s "could" require trimming on a stock setup. Adding more caster might give you more clearance at the body mount but will probably cause more trimming needed from the bumper. Tires, even though the same size, can measure to be a different size (aka bfgs run small, some tires run true). Every setup is going to be different because everyone's alignments can be different. More negative offset increases your scrub radius which can cause more rubbing. You don't really want to go more positive offset from stock. Lifting does not change your scrub radius, so contrary to popular belief, if you rub on your stock height... you will most likely rub when "lifted/leveled". Sure you are physically raising the height of your body mount and bumper from the tire but under compression it would still rub.
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
