FS: 5th Gen 2017 SR5 Premium 4X4 - Rosemead, CA - $42000
8 Attachment(s)
For sale:
2017 Toyota 4Runner SR5 Premium 4x4 Super White 80,500 miles (and will go up as this is my daily) VIN: JTEBU5JR7H5470396 Condition: Very good Asking Price: $42,000 obo Location: Rosemead, CA 91770 Items Included (on the vehicle): •BajaRack Full Rack •BajaRack Ladder •Rago Fabrication Ditch Light Brackets (pair) •ARB Snorkel •Methods 701 Bahia Blue(set of 5) •Falken Wildpeaks AT3w (Less than a year old, ~10k miles)(set of 5) •Demello Flat Top Steel Front Bumper •King Shocks Front(adjuster)and Rear(no adjuster) o700lb King springs front o800lb Ironman 4x4 springs rear •SPC Upper Control Arm •Rago Fabrication trunk area window panels •ICS Fabrication Dash Mount •Rago Center Console Mount w/ Bridge •Front and Rear Dash Camera (wires hidden) •Power Tray •Switched power wire to Trunk Area oBlue Sea Systems Breaker Switch oBlue Sea Systems Fuse Block oBlue Sea Systems 12v USB and DC Socket combo w/ voltameter •Baja Designs Squadron Sport Amber Fog Light •KC Hilites C-Series 30”Driving Combo LED Bar+ Light Switch •Rock Lights (set of 8)+ Light Switch •RCI Steel Skid Plates (Engine, Transmission, and Transfer Case) •ShrockworksSlidersFlat (Discontinued for flat) •Revolution Gear 4.56 Gearing Front and Rear Axle •BMC High Performance Engine Filter •K&N Cab Filter •Custom Dual Drawer System •Interior LED Bulbs (No Halogen bulb remaining) •Exterior LED Bulbs (F&R Turn Signals, Reverse Lights, Courtesy Lights) •GTRLighting Ultra HID Low Beam •WeatherTechWindow Visors •Wheeler’s Front and Rear SuperBump Bump Stop •Pedal Commander •Rad Rubber Engine Splash Guards Items Included (off the vehicle): •SDHQ Switch-Pro Mount (replaces the trim panelto the left of dash) •OE Roof Rack Rails and Cross Bars •BajaRack Maxtrax Mounts (pair) •Rago Fabrication Lower Control Arm Skids •Rago Fabrication Lower Control Arm Skid Hardware (Discontinued) •Overland Custom Designs Front Sway Bar Adjustable End Links •Overland Custom Designs Front Sway Bar End Link Parts •Toyota Super White Touch Up Paint Pen •Toyota AC System Cleaning Kit •CoverCraft Windshield Sun Visor Block Items Not Included: •Front Sway Bar (Taken off for full droop) Maintenance Performed: •Oil and filter change every 5,000 miles •Transmission, F+R Differentials, and T-case service performed at 55,000 miles •F+R Differentials fluid changed at ~70,000 miles •Drive shaft and UCA Ball Joint lubed 6 months •Windshield Wiper Inserts replaced annually (Current ones are 1 month old) •AC system cleaned annually •Brake Pads replaced at 55,000 miles •King Shock Nitrogen checked and refilled at 75,000 miles •5 Tire rotation every oil change Known Flaws: •Paint chipped on the fiberglass front bumper filler piece •Scratches on the rear bumper •One small dent on passenger rear door. •Some scuff on radio head unit on volume knob area •Paint chipped on ladder and roof rack (touched up paint applied) •Some rock rashes on the wheels. Please refer to my personal OneDrive for more high resolution pictures |
More Pictures
8 Attachment(s)
More pictures
More pictures pt2
4 Attachment(s)
Additional pictures
PDF file for all the necessary information
1 Attachment(s)
Please read the PDF file that contains all the necessary information regarding this vehicle.
Inside, you will find the detailed listing of what's included and how much they cost, as well as explanation for known visual flaws. Finally, a simple FAQ is present to answer some common questions. |
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
