Time for a transmission oil chance - question about brands of ATF
We have a '99 that just turned over 200K, and due for its 60K transmission oil change. I think the last time I did it I used Valvoline, but ended up with a few unused quarts of O'Reilly ATF from another vehicle. Is O'Reilly ATF a decent choice? It's the right type, and hate to dump unused ATF.
As long as it's Dexron III it will be fine.
Quote:
Quote:
I know Toyota does not make its own transmission fluid, but that's all I've used over the years.
Complete fluid exchange every 100k miles, and a filter change around 400,000 miles simply because I was curious (the original looked fine). The truck now has 518,000 miles and shifts the same way it did when I bought it new. Andreas |
Quote:
Quote:
Quote:
Quote:
Yes sir. All maintenance/repairs/upgrades by me since day one. Just trying to get my money's worth. :) https://hosting.photobucket.com/imag...Render(34).jpg https://hosting.photobucket.com/imag...Render(35).jpg Andreas |
I think the valvoline ATF full synthetic is compatible with lots of ATF fluids. This is what the trans shop added into my 2000 LandCruiser transmission after it got its trans rebuilt.
That's what I use valvoline that meets the dexron II and III specs. We have several threads in the 3rd gen section on this topic already. That's been discussed in great detail. Along with the tech bulletins from Toyota stating not to use T4 as isn't not a replacement for this particular transmission. :)
Sent from my SM-A505U using Tapatalk |
It’s got a drain plug. Use your flavor and do it often.
I do it every 30k miles. It’s always been 4qt removed so I don’t even bother checking the pain in the arse dipstick. I’ve been using supertech from Walmart for years. Sent from my iPhone using Tapatalk |
Quote:
Sent from my SM-S908U using Tapatalk |
Quote:
It has plenty of battle scars. But all original paint. Andreas |
Quote:
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
