Anytime Backup Camera Wiring/Switch Panel Question
Hi All -
I have finally reached the point where I am running out of switch blanks and starting to look into switch panels/wiring options. I was wondering if you guys had thoughts on 2 things: First - Has anyone wired their anytime camera setup to a switch panel? I've tried looking, but couldn't find anything, but I'm a bit of a noob when searching these forums. Second - I see a lot of reviews/opinions on various switch panel, but haven't seen much around the switch panel options from Nilight/Rough Country, and wanted to see if anyone has thoughts/experiences to share. Nilight: Amazon.com: Nilight 6 Gang Switch Panel Universal Circuit Control Relay System with Fuse Wiring Harness Automatic Dimmable ON-Off LED Switch Pod for Cars Trucks Boats ATV UTV SUV, 2 Years Warranty : Industrial & Scientific Rough Country: Muliple Light Controller | 8 PANEL | Rough Country |
First.....I would not put the anytime camera on an auxiliary switch panel....the camera rocker switch is wired into the harness that is at the back of the head unit. You would have to run those wires to the engine bay (where an auxiliary switching resides) in order for it to have control. The part of the auxiliary switch that is in the interior is just a control interface that sends a signal to the unit under the hood. you also have to consider that the camera rocker switch is a 3 position switch that handles two circuits. If you were to use the auxillary panel, you would have to use two buttons to accomplish the same functions.
Second...dont know anything about those, but i have an 8 switch Auxbeam and its been great for the last two years. |
Quote:
Quote:
Thanks! To be honest, I tend to heavily lean on trail4runner.com - and when they wired their ABC, it seemed suggestive that it was simple/possible. Also, glad to hear that the Auxbeam is working out for you. Again, some of the comments I heard on their Auxbeam install scared me away, but maybe I should reconsider. For the most part, I really wish there as room for just one more switch (1 for amber, 1 for whites, 1 for chase, 1 for ABC), but with only 3 switch blanks, I'm not considering a switch panel. I've been searching high/low for a switch that would fit in either 1) center console where seat heater blanks are, or 2) switch that would fit in right panel of the steering column. I've only seen USB outlets that would fit Appreciate your input |
Quote:
As the anytime harness is behind the radio a convenient location for a switch is in the OEM single switch opening in the dash panel to the right of the steering column. Remove the blank and insert a switch. Good convenient location without taking up a spot in multi switch panel. This is where I mounted my switch.
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
