Stock electrical system excess capacity?
With the stock alternator (and pretty much everything else stock), how much spare capacity is available from the alternator in an 2021 ORP assuming everything else (that makes sense) is on? The main loads would be headlights and running lights, starter battery charging, audio system playing, and either a cold weather situation (heat on, seat heaters on, rear defrosters on) or a warm weather one (A/C on max). Any other big loads I missed there?
Trying to size a charger for a second battery bank, and I don't want to nuisance blow the alternator fuse or keep the starter battery from charging. Thanks! |
The fuse box covers will tell you by the amp rating of the fuses. Big ones off the top of my head are going to be the PTC heater and any other heat strips, the brake booster, but that is a short duration draw, and the inverter
Quote:
It's like Jeremy556 said: You likely have a 130A Stock Alternator! Size-up your loads; based on BOTH of your fuse-boxes: (Main [ENG RM]) and (D/S fuse-box covers). Once you calculate your standard-(Typical-loads), you subtract that# from the alternator's capacity (or 130A); I did it with my 4Runner and calculated using about 80% of the stock alternator's full output... (Not considering the fuel-injection/IGN Systems, and 27 compu's in operation!) NOT GOOD for any sizable "Add-On's!" So I went with the Power Engineering 270-XP to handle ANYTHING that I might; or already had added to my truck! Never have had a problem... "Loadwise!" ...and it charges the ODYSSEY EXTREME 1500T AGM @14.64V and 200A curb-side idle! ~rig~ Best to you! |
Keep in mind that the alternator ratings are at rpm and not at idle.
Quote:
That's true, but that doesn't change the alternator's "FULL OUTPUT CAP!" On the other hand... the "Power Engineering 270-XP puts out 200A @Curb-side idle, (compared to Denso 130A full output); more than enough for add-on's e.g., LED lighting, a fridge, BIG Sub-woofer system...etc, ask me how I know! LOL!:whoo: ~rig~ Best to you! |
Thanks for the replies.
I think I'm stuck with the stock alternator, unless Power Engineering's 270-XP can fit on a 2021 ORP (it's not their list). Does anyone know what changed between the 2017 (last year listed for the 270-XP) and and 2020? It's weird because Toyota Parts says that the stock alternator (270603126084) fits a wide range of 4Runner, way back to 2015 and before. An interesting data point: these folks claim to have a 250A alternator that fits 2014-2022 4Runners. Any experience with them (Power Bastards)? 250A High Output Alternator for Toyota 4Runner, 2014 - 2022 4.0L V6 (241c.i.) - 11764-250-HD1-1 | PowerBastards.com | PowerBastards.com Thanks! |
Quote:
"Trying to size a charger for a second battery bank" Can you expand on what it is you are doing? A second battery bank for what? An alternator is a pretty good battery charger by itself. |
Quote:
I'm sending a request to Singer as well; he seems to have a good rep. Power Bastards, not so much from reviews I'm seeing elsewhere. Could just be the usual problem of if you sell enough of a thing, some will be bad, so if you sell a lot you get more negative reviews. But still a caution flag. How about Mechman? They have a part they claim is direct-fit. Quote:
29V (absorption voltage) * 25A (preferred charge rate) = 725W 725Wh/0.88 (charger efficiency) = 823W (load at alternator) 823W/13.2V ~= 63A new load on the alternator Those are all vendor spec numbers for the battery and charger. Yes I'm ignoring cable losses for now. 15 feet of 6 AWG would be about 0.8V drop, so really closer to 66A at the alternator. It's 24V because the wiring, fuses, etc. all get funky big at 3kW. I'd rather do 48V but I can't get the packs that fit the space in 48V, and the 24V packs I can get can't be run serial, only parallel. Thanks again! |
Quote:
Product Result – DC Power Inc. ~rig~ Best scfw0x0f! |
Quote:
Quote:
Be careful about using Mechman; High Output (hair-pin) Alternators are NOT just built by squeezing more windings & capacitors in the End-frames... They're (Basically) High Efficiency Heat-Sinks that are able to remove tremendous amounts of Heat from the windings, and X-fer it to where it's NOT Objectionable! ...Something to keep in mind when choosing an alternator; they're Not All Built the same way! rig |
Okay so this is fascinating. Tagging
@rigtec
and
@AMLOR
on this, and
@DCPower_Anthony
Just spoke with Anthony @ DC Power. Apparently the main problem with more recent 4Runners is that Toyota moved the alternator slightly, and he hasn't been able to get a newer truck in his shop to work out the fitment kinks. Might just be some spacers. I'm no where near Orange County but maybe some other reader would be willing to have their truck be a test subject? He's offered to send out a unit to someone who can wrench it themselves (that's not me, I stick to weird electrical stuff :) ) and take it back if it doesn't fit. Any takers? Or anyone near OC who is willing to be install #1? |
Quote:
As mentioned above something has changed after 2017. I either need a 4Runner here or I can send one to someone who's willing to give it a go. Nice to see this forum is still thriving! |
Quote:
Ask Anthony what he suggests... maybe you can find out what changes are needed, and tell @DCPower_Anthony " :noidea: ~rig~ Best scfw0x0f! |
Quote:
The parts call for the same alternator between the years. I had two customers have issues with installation. They weren't doin the work themselves so it was hard getting their mechanic to work with us. |
| All times are GMT -4. The time now is 05:37 AM. |
Copyright ©2000 - 2026, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2026 DragonByte Technologies Ltd.
User Alert System provided by
