FS: 2000 4Runner Limited 4x4 - Seattle WA - $12.5K
8 Attachment(s)
Hi,
UPDATING MY PRICE TO BETTER REFLECT THE WA MARKET - I am selling my 2000 Toyota 4Runner. This is the 3.4L V6, 4x4, Limited trim. I have the clean title in hand. We can meet in and around Bothell,WA for a test drive. I can send you more pictures (odometer, roof rack, undercarriage, etc) The car currently has 183,XXX miles and I am the second owner. It has been garaged since I bought it in 2016 in California. The sunroof, 4x4, lower gears and rear diff all work perfectly. No rust on the undercarriage/frame. The truck has the following upgrades: ARB bumper Rigid fog lights and ditch lights HID Retrofit headlights Shrockworks sliders OME suspensions SPC Upper Control Arms Dick Cepek tires (and spare tire) Frontrunner full roof rack ARB rear differential breather The following preventive maintenance has been done over the past 3 years: Full flush of all fluids New Denson Radiator New radiator hoses and clamps New thermostat New OEM lower ball joints New OEM filters New Exhaust New Catalytic Converter New Front Brakes (rotor and discs) Upgraded Pioneer sound system, with bluetooth connection I will give you a full OEM timing belt/accessory belt/water pump kit, since I am not sure when it was last changed. I will install a new Costco battery this coming week as well, just to be safe. The two negative things about the truck: 1- the AC will need to be refilled. The compressor works and does not leak, but I never use AC and the last refill was years ago 2- the antenna broke and will need to be replaced if you want to use AM/FM radio I will sell for $12,500, which I believe is fair considering the condition, maintenance and upgrades done. Once again - located in Bothell. I will only accept cashier's checks and will request to be present with you at the bank when said check is issued. One can never be too careful. |
Still for sale?
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
