dash warning lite
my battery lite and my brake lite
are on at the same time all the time going out once in a while but not for long. i don't know if it's a short or what. any one have nay ideas ? |
If the brake and charge lights come on during revving of the engine then it's a sign that the carbon alternator brushes require replacing as this is the mileage for them to wear out. In alternators the brushes wear out on average every 140-170 000 miles where on the dashboard the brake & charge light both come on at the same time. About half of the auto electric shops in your local yellow pages sell carbon alternator brushes and copper solenoid starter contacts for about $5/pair.
Another way to verify that the alternator is not charging is while the engine is running bring a metal screwdriver or any metal object near the alternator and if the alternator is working properly then it should act like a magnet and grab the screwdriver. For carbon brushes R&R: http://www.4x4wire.com/toyota/mainte...rnator_brushes http://www.toyotaoffroad.net/afertig...torbrushes.htm http://perso.wanadoo.fr/adherence.4x...nateur_kzj.htm http://www.automotiveforums.com/vbul...d.php?t=166525 http://www.toyotanation.com/forum/sh...270&forumid=10 http://forum.ih8mud.com/79-95-toyota...sh-change.html http://www.pirate4x4.com/forum/showt...r+brush+holder http://www.bitwalla.com/cruisers/art...lternator.html http://www.barneymc.com/toy_root/tec...c/altrnatr.htm ftp://ftp.bauchan.org/Toyota/electri...alternator.zip http://forums.bauchan.org/portal/vie...ds.php?rid=177 For decoding the dashboard lights: http://www.powerbase-auto.co.uk/alternator_faults.htm http://members.1stconnect.com/anozir...alternator.htm Here are part #'s for Toyota alternator carbon brushes and copper solenoid starter contacts which are used in about 95% of all Toyota vehicles. Toyota alternator Brushes with holder: Toyota # 27370-35060=$29 CDN Honda # 31105-PZ1-003 Metro # 39-82003 (www.metroautoinc.com ,Pomona,California) Unknown brand name # F4019-53035 Alternator brush only (qty:1 brush unless otherwise stated): AC Delco # E724 AC Delco # E731 (side wire and concave tip) Ace Electric # DA-61 (brush only),S-5367 (brush holder) Beck Arnley # 178-1669 (side wire and concave tip) Beck Arnley # 178-1376 Borg Warner # X580 (side wire and concave tip) Canadian Tire # 19-2050-6=$4.49/pair Daihatsu # 27370-87302-000 Daihatsu # 27371-63020-000 Daihatsu # 27371-87501-000 Daihatsu # 27371-70300-000 Echlin # E601=$8.16 CDN/pair (UAP/NAPA) Echlin # ECHE601 Echlin # EC480 Echlin # ECHE480 GP Sorensen # 255047 (side wire and concave tip) GM # 94123056 GM # 96054118 Honda # 31144-PD1-004=$9.72 Honda # 31144-PD1-0040 Honda # 31144-PD1-0030 Honda # 31150-PR7-A01 Honda # 31150-PTO-003 Hino Industries # 021660-0390 Hino Industries # 021660-0510 Isuzu # 8-94123-056-0 Isuzu # 8-97032-308-0 Isuzu # 8-97032-310-0 Mazda # 021660-0390 Mazda # 021660-0510 Mazda # KL47-18-W75 Metro # 38-82001(side wire concave tip) (www.metroautoinc.com ,Pomona,California) Mileage Plus # E601SB Mitsubishi # MD604474 Mitsubishi # 21660-0510 Niehoff # WA571 (side wire and concave tip) NipponDenso # 021660-0390 NipponDenso # 021660-0510 Standard # JX-116 (side wire and concave tip) Subaru # 021660-0390 Subaru # 021660-0510 Suzuki # 31631-82610 Suzuki # 31656-82611 Suzuki # 021660-0510 Toyota # 27370-42010 Toyota # 27370-75060 Toyota # 27371-63020= (up to 9105) (side wire and concave tip) Toyota # 27371-70300=(9105-9511) Toyota # 27371-76004-71 UAP/NAPA # MPEE601SB Victory Lap # FAX57=$4.49 CDN/pair (Canadian Tire) Wilson's Electric # 26-29-7534 (side wire and concave tip)=$2.20 each CDN (Diesel Auto Electric)(Parts for Trucks,box of 10 for $3.40 CDN) Specifications: Length=15 mm Width=7 mm Thickness=5 mm Lead length=49 mm These Honda alternators are the same except the pulley must be swapped: 1986-89 Honda Accord (Carb),the EFI can be used but the voltage reg must be swapped 1990-93 Acura Integra For alternator upgrade: http://www.off-road.com/toyota/tech/100alt/index.html http://www.4x4wire.com/toyota/tech/alternator http://home.earthlink.net/~twopapa/bigalt.htm http://www.toyotaoffroad.com/Article.../Chevy_Alt.htm http://www.alternatorparts.com/Toyot...lternators.htm http://www.rocketcityrockcrawlers.co...%20Project.pdf 24 Toyota (NipponDenso now called Denso) starter repair sites: http://www.off-road.com/4x4web/toyota/tech/starter/ - http://www.4crawler.com/4x4/CheapTricks/Starter.shtml http://char.tuiasi.ro/vw/reality/rog...s/Starter.html http://yotarepair.com/startercontacts.html http://www.toyotaoffroad.net/afertig...rterrepair.htm http://www.4x4wire.com/toyota/maintenance/starter http://www.yotatech.com/~corey/tech/...r/haveblue.htm http://www.sleeoffroad.com/technical...er_rebuild.htm http://www.startercontacts.com/install.htm http://www.startercontacts.com/image...loded_view.jpg http://www.colorado4x4.net/tech/star..._contacts.html http://www.barneymc.com/toy_root/techneek/starter.htm http://perso.wanadoo.fr/adherence.4x4/start_bj.htm http://www.automotiveforums.com/vbul...d.php?t=166530 http://www.toyotanation.com/forum/sh...312&forumid=10 http://www.toyotanation.com/showthre...312&forumid=10 http://www.toyotaoffroad.com/Article...er/starter.htm http://www.tacomaterritory.com/boophoenix/starter.html http://www.tacomaterritory.com/booph...er/image01.jpg http://www.yotatech.com/f128/starter...4runner-76347/ http://www.team-integra.net/sections...ArticleID=1079 http://personal.utulsa.edu/~nathan-b...g/1starter.pdf ftp://ftp.bauchan.org/Toyota/general...id_contact.zip ftp://ftp.bauchan.org/Toyota/electri...rter_motor.zip http://forums.bauchan.org/portal/vie...ds.php?rid=176 http://forums.bauchan.org/portal/vie...ds.php?rid=153 Starter contact kits (8mm ID hole): Ace Electric # S-5263 (only two contacts) Ace Electric # S-5264 (only two contacts) Metro # 66-82104 (only two contacts) (www.metroautoinc.com ,Pomona,California) Toyota # 28226-72010/80 (battery side)(also1KZTE-2LT-1KZT) Toyota # 28226-72080 (8808-9108) Toyota # 28226-16130 (9108-9308) Toyota # 28226-55050 (9308-9511) Toyota # 28226-70040 (9308-9511) Toyota # 28226-72040 (motor side if needed) Toyota # 28226-72010 (8808-9511) Toyota # 28226-74070 (9108-9511) (2000 Tundra & others) Toyota # 28226-22050 (2000 Tundra & others) Toyota # 28226-66060 (1993-1997 Land Cruiser 2.0 KW starters) For others besides 22R series: Toyota # 28226-54220 (motor side) (2LTE, 3L..LN13# IKZTE, 2L#, KZN130,LN108,112,85..4FC) Toyota # 28226-54250 (Diesel Surf 2.4TD, contains a new end cover and gasket) Toyota # 28226-54320 (battery side) (2LTE, 3L..LN13# IKZTE, 2L#, KZN130, LN108,112,85..4FC,3B-1HZ-BJ73-HZJ7#-1KZT-KZJ70) Toyota # 28226-17030 (battery side) (1H#-HDJ80-HZJ80) Toyota # 28226-56250 (battery side) (3B-1HZ-1PZ-PZJ7#) Starter contacts only (8mm ID hole): Ace Electric # S-5231 Ace Electric # S-5293 (crescent moon shape) Ace Electric # S-5295 (crescent moon shape) Metro # 66-82106 (www.metroautoinc.com ,Pomona,California) Tons more at: http://www.metroautoinc.com/PDF%20Fi...%20Contact.pdf Toyota # 28226-70040 Wilson |
WOW, Thanks,
| All times are GMT -4. The time now is 12:09 PM. |
Copyright ©2000 - 2026, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2026 DragonByte Technologies Ltd.
User Alert System provided by
