Air Circulation Button
Hey Everyone,
I was wondering, does anyone else have an issue where you press the button to allow the air to circulate in our car? I turn it on, but for some reason, it turns off. Is that normal? Thanks in advance. |
Quote:
Quote:
Quote:
My button keeps turing itself on - to recirculate. I want it OFF most of the time so that I get fresh air. It is a pain in the butt and I've never seen this on any other vehicle before. Not sure what it is trying to do...
Quote:
my fj did it and now the 4runner does the same thing. i push the button, the light turns orange and no outside air is coming in which is what i want. then after some time passes by i notice air is starting to come through the vent and the light is off on the button.
RTFM!
There, you will find that it says, "When AC is turned to Max A.C., the inside recirculation button will automatically illuminate." Whenever you turn the system off and then back on, it will recirculate again as long as the temperature knob is set to "Max A.C.". You can always make it take in outside air after turning it on Max AC by pushing the recirculate button, but it will come back on if the engine or AC is turned off. For all other temperature settings, the default is recirc OFF and must be turned ON if so wanted. |
you saved the day... i was gonna say... but no, ya did just fine!:fro:
Quote:
Quote:
All this button does is change from the A/C taking in outside air or just recirculating the inside air with the A/C. If you want outside air to flow through the car set the fan switch to low and voila air will flow. If the temp is set you Max A/C you wont be able to deselect this or turn off the A/C. Every car I've ever had works like this. |
What!?!?! The 4Runner comes with a manual!? Lol, it's amazing how people would rather turn to the internet to get answers from random strangers instead of reading the manual.
Quote:
RTF-POST! His question was not about max a/c. I understand what he is asking - when fan is off, and esp driving at highway speeds, a small amount of air still comes through the vents, which can be annoying when you are comfortable with the temperature inside the car. To stop this trace air from entering the cabin, you can press the recirculate button; HOWEVER, for some reason in the 5th gen 4runner, it will only stay on for about 10 min before it turns itself back off. I have noticed the same problem, and do not know of a fix, but will try the "hold for 3 sec" method |
Quote:
The manual also states that the car will automatically switch between the recirc and fresh air based on humidity in the cabin.
Bottomline....
I think it's like an "emergency fresh air" source in case you shat yourself in front of the the Mrs. or maybe even a new date (and you could always blame oit on the catalytic conv.) Ok..there...I said it... I couldn't possibly be the only thinking that.....right? |
| All times are GMT -4. The time now is 09:57 AM. |
Copyright ©2000 - 2026, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2026 DragonByte Technologies Ltd.
User Alert System provided by
