OEM rear locker question
So I just got a 97 T4r that has a dash button that says RRLocker. I pushed it and a dash light was blinking saying rear locker.
My question is, is it supposed to blink? How can I tell if it is locking? |
Two easy ways to test if the locker is engaged.
1. With locker button pressed, parking brake off, jack up one rear wheel and try to rotate it by hand. If it turns then the locker is not engaged. 2. Find a parking lot (not gravel) and drive a few very tight circles. If the locker is working you will feel and hear the rear tires slipping and chirping as they break traction. |
The locker will NOT engage unless you are in 4LO. In 2WD and 4HI, it will just blink. If you want to use the locker in 2WD and 4HI, you can do the easy "grey wire mod". You can do a search and there is a lot of info on this. However, the "grey" wire is only grey on Tacos, it's a different color on 4runners, but I don't remember what color - I do know it's like red with a yellow stripe, or maybe blue with a red stripe... something like that.
Thanks for the help, now I am going to go try it out. So when in 4 low and the locker button pressed, will the dash light blink or stay light or what?
Quote:
Quote:
Retrofit Electric Locker |
Thanks for that link. I want to test this thing out ASAP.
Quote:
Sorry to be dumb, but before I grind anything- Whats the right procedure to put it in 4 wheel drive?
DO NOT TURN ON PAVEMENT WITH THE REAR LOCKER LOCKED!!!! Unless you feel like buying some new parts. It "should" skip. But it could also break things. If you are going into 4lo to try out the locker, I would do the following.
Find a dirt road put truck in "N" put transfer case lever into 4Lo Push rear locker button. put truck in to drive Drive forward. The rear locker light should stay on steady once the locker is engaged. You can turn if you are on a loose gravel road. If it does not engage, the actuator can be removed and cleaned up. They will typically stick if they are rarely used. Once it starts working regularly for you, you should try to engage it a few times a year to keep it working properly. |
Quote:
Quote:
J |
I worked at ARB for 5 years. One of the standard tests after fitting an air locker is to drive the vehicle once around the parking lot and test the engagement. You will NEVER break anything doing this as a quick test. You will hear and feel the tires chirp within a second or two and then you turn the locker off. You continue the turn to ensure it has disengaged properly. It's easy and harmless. Of course you're not going to start doing laps of a lot in low range and locked rear, that's stupid and pointless, but a 10 second test to check operation is perfectly fine.
Not that the parking lot method is going to grenade the diff or anything, but you could just jack up the rear and spin the tires. Obviously they will turn the same direction if it's locked.
Quote:
1) ARB is the pretty much the strongest locker on the market. Factory E-Lockers are not quite as strong. They are definitely not junk, just not an ARB. 2) If some one is not sure what a Locker is, they are probably not familiar with how they work. One or two quick turns may mean the same to them as doing doughnuts. Until the OP is up to speed on there function, it may be better to be in "safe mode". J |
| All times are GMT -4. The time now is 07:38 AM. |
Copyright ©2000 - 2026, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2026 DragonByte Technologies Ltd.
User Alert System provided by
