4th Gen T4Rs
https://www.toyota-4runner.org/4th-gen-t4rs/)
| ontoy |
11-05-2004 04:11 PM |
is this the oil drain plug?
| djlandkpl |
11-05-2004 04:29 PM |
The oil drain plug is directly above an oval hole in the skid plate. There may be a plastic cover covering the hole.
| ontoy |
11-05-2004 04:37 PM |
right above that plastic oval hole in center of the back skid plate right. then this should be it then.
| ontoy |
11-05-2004 07:28 PM |
| linhsy |
11-06-2004 12:04 AM |
ontoy, how many quarts did you put in the engine?
| ontoy |
11-06-2004 01:41 AM |
5.5 quarts. I checked the oil level in the dipstick and it is between min - max, so it's all good.
May I give you one suggestion for next time. Your choice of Mobile 1 is very good. However I would use 10w30 next time. I have used 5w30 and 10w30. I have had them both analyzed afterwards. Believe me the 10w30 holds up alot better.
| All times are GMT -4. The time now is 05:14 AM. |
Copyright ©2000 - 2026, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2026 DragonByte Technologies Ltd.
User Alert System provided by
