Front hitch mount & winch?
Hey all,
I would like to know if I would be able to use a front hitch mount and install a winch to it? Basically i would like a winch that I can easily remove and go back to a stock look, without changing out my front bumper. Is it even possible to add something like this in the front? Sorry if I am using the wrong terms for the accessories. Noob here! Hope you all understand what I mean! Searched the forum but didnt find anything without changing the front bumper... Thanks in advance! |
well anything is possible. I don't think there is a kit available. I'm sure if you went to a fab shop they could build something like this for you.
Quote:
I figured that would be the best route to go, but also the most expensive. Thanks |
Quote:
No way I remember the name of the product, but I got it at "camping world". They welded two small "female" brackets to the bottom of the front frame rails. The brackets lined up perferctly with two already existing trim pieces on the bumper which could be removed when needed. Then the "male" ends of the tow bar would slide into the bumper area and connect to the brackets. The system worked so well, I took it to a welding shop and had them build a second bar with the same size male ends and a cross bar with a class C reciver in the center. This way I could use my warn winch, which came from the factory on a platform that had a class c "stinger" already built in, either in the front or rear of the vehicle. It worked very well! Still have the winch, sold everything else. But I bet you can still do something like this but you might have to either remove the lower portion of the 4R bumper or cut a couple of small holes just in front of the front frame rails. |
Quote:
That sounds EXACTLY what I am looking for. Happen to have any pics? |
Quote:
Jake |
Quote:
Also thanks for the contact info. I did contact a couple of welders and they gave me an astronomical price.....4 digits....:toilet: I guess NYC isnt 'custom-friendly'.....? Well, again, thanks for the info. If I find a welder willing to work with me, I will contact you. |
Quote:
According to the site, there are at least 4 of these stores in NY, hopefully one near you and you can go check it out. |
I did a little more research, and I found this web site:
www.roadmasterinc.com If you go there, then to the bottom of the initial page, you will see a link to the owners manual. Click on that link then go to page 10, figure 12, and in the drawing you will see the brackets I am talking about. You may be able to order the brackets "only" from roadmaster, then fabricate the rest. |
Jtraskell, you sir are the SHIZNIT!:hatsoff:
Thanks for doing my homework for me. I didn't really know what I was looking for (visually). Looks like I have some calls to make... |
I think this might be what your looking for. You can add whatever you want to the front hitch
CURT 31367 at AutoAnything |
Quote:
| All times are GMT -4. The time now is 12:32 PM. |
Copyright ©2000 - 2026, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2026 DragonByte Technologies Ltd.
User Alert System provided by
