Toyota 4Runner Forum - Largest 4Runner Forum
Toyota 4Runner Forum - Largest 4Runner Forum (https://www.toyota-4runner.org/)
-   3rd gen T4Rs (https://www.toyota-4runner.org/3rd-gen-t4rs/)
-   -   Changing Bulbs in A/C unit! (https://www.toyota-4runner.org/3rd-gen-t4rs/83928-changing-bulbs-c-unit.html)
OBXRunner 02-28-2011 10:49 PM
Have you ever had a bulb in your AC unit go out. It can be pretty annoying. This write up describes the way to fix that issue by replacing the bulbs.
Parts needed:
Part number: 81850-35040 Description: lamp assembly These are the larger ones with the white base-these go in the display
Part number: 81850-35050 Description: lamp assembly These are the smaller ones with the black base-these are for the buttons
Pic of light bulbs used in fixing AC display
http://i666.photobucket.com/albums/v...4.jpg~original
This is my before shot. Notice that the display is completely burned out and can not be seen at night. The lights for the buttons were fine but I went ahead and replaced them while I had it all dissassembled.
BEFORE: AC unit before-display lights not working
http://i666.photobucket.com/albums/v...9.jpg~original
Step #1: Disessemble the dash.
http://i666.photobucket.com/albums/v...0.jpg~original
Step #2: Unscrew the screws holding the AC unit to the vehicle and carefully pull the AC unit out,
http://i666.photobucket.com/albums/v...1.jpg~original
Remove the AC unit by unplugging the cables.
Remove the two small screws on both sides of the AC unit.
http://i666.photobucket.com/albums/v...3.jpg~original
Using a screwdriver, carefully separate the black front from the white housing by carefully prying on the tabs. They are plastic so be careful!
Remove the light bulbs by slightly twisting the bulb to the left with a screwdriver and then pulling them out.
http://i666.photobucket.com/albums/v...6.jpg~original
http://i666.photobucket.com/albums/v...5.jpg~original
Replace the light bulbs and reassemble.
AFTER: AC unit after-display lights working
http://i666.photobucket.com/albums/v...2.jpg~original
Hope this Helps!
:bigok:
GottaBeTRD 03-01-2011 01:06 AM
nice write up! for those of you that want a custom color the little bulbs in LED terms are a neo wedge type III or 3mm bulb and the bigger ones are Neo Wedge type 4 or 4mm
4ganger 03-01-2011 02:07 PM
this should be added to the FAQ if it is not there already... :-D
OBXRunner 03-01-2011 08:18 PM
Quote:
haha thanks! just thought alot people would like to see what they are getting into before the start tearing the dash off!
4ganger 03-01-2011 10:32 PM
Interesting... I have a 2000 SR5 Sport but my A/C unit looks totally different. I don't have the screen like you have but istead two rotating knobs for temp and vent control.
Wondering if my bulbs will be different. Anyone know?
GottaBeTRD 03-01-2011 11:51 PM
the 3 buttons on top take 2 of the smaller bulbs and i think that your HVAC have 3 bulbs. (the bigger ones) i have the 3 knobs so its a little different but in reality having extra bulbs isn't a bad thing. you have some back ups
ksroqclimber 05-28-2011 09:49 AM
Added to Tutorial & Documentation Reference.
Tucson4runner 07-02-2011 04:36 AM
these bulbs can be bought at radioshack.....?
SRSRunner 07-02-2011 08:19 AM
Quote:
Can they? I had to go to the dealer when I did mine..
Great write up! I did that right after I bought mine, fairly easy to do, but this will help anyone who hasnt had to do it yet.
SCRunner12 07-02-2011 10:44 AM
I was wondering about getting new bulbs in. Anyone put anything other than the stock green? I was thinking of going with white if it works.
Tucson4runner 07-06-2011 03:08 AM
idk i was asking because i wanted to get blue if available but if they are only available at the stealer then i guess green will have to do
oh and fyi it appears that your runner is missing a door in your signature picture. just thought id give you a heads up if you hadnt noticed :lmao:
Qyota 07-06-2011 09:46 AM
I replaced mine with LEDs about a year ago. Now they barely work. They flicker on and off randomly. Not sure if that's a problem with the LED, or the connection at the PCB. Either way, I think I'll be replacing these with regular old bulbs soon (minus the green condoms).
SRSRunner 07-06-2011 12:16 PM
Lmao... as for the lights, Theres alot of people on here that have done led lights which I found out after the fact.. Where they got them I dont know. I didnt even think to look around for leds, My drive light was out at the time also so I just went to dealer and got bulbs for everything.
BrianSD_42 07-06-2011 01:50 PM
ALL MY BULBS ARE OUT@!
I guess that is what happens at 204k
GottaBeTRD 07-06-2011 09:02 PM
yeah there are dozens of threads on the LED swap (changing the color of your lights) I think autolumination,com sells the colored halogen bulbs just dont get their LEDs
If your LEDs are flickering it is a definite sign they are done for some good LED sites are SuperbrightLED's.com and VLEDS. i know quite a good bit on these just from doing them all the time so feel free to ask questions, Im not to familar with what years take what bulbs but i can prob tell what bulb it is with a picture
Copyright ©2000 - 2026, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2026 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2026 DragonByte Technologies Ltd.
