Simple Improvements to JBL MultiDisk System?
I've read through several threads on people who didn't like the JBL 10 speaker system. I'm not that unhappy with it, although it could be better. I've played extensively with the settings, and can usually get it to sound halfway decent (sweetest spot is actually in the back seat).:guitar2: :violin:
Because of the complexities of changing this factory system, it seems like either simple changes, or ripping the whole thing out & starting over are the only/best solutions. Someone suggested installing a resister or a volume control on the center surround dash speaker . Is this possible & has anyone done it? I do find myself wishing I could tone this speaker down some - plus it seems like it robs power from other speakers. So maybe we could consolidate some of the various ideas that's been floating around to improve this system - but I'd really like to use the KISS principle here, or do nothing at all. :hello: |
I agree...that center speaker is ridiculous.
I hated it so much that I disconnected my center speaker altogether. :bash: You need to unsolder the leads from the back of the speaker, but it's pretty easy because you don't need to disassemble your whole dash to do it. Just pop the speaker grill out and you have access to the speaker. Afterwards, you need to completely re-tweak your bass and treble settings. I did it when I got my 4Runner about two years ago, and I've been SO much happier with the sound. BTW, I left the center speaker in place and plugged my CB radio's aux output into it. Now it has a useful purpose in life! |
So Chris - Is the sound now still surround, but just without the center speaker? In other words, when you switch between surround on & off - does it sound different?
Sure, the surround mode still works.
But (if I recall correctly) I don't have it turned on because I think it "colors" the music too much. I'm more of a purist who wants to hear what the artists originally intended. However, to each his own. If you're going to perform the speaker-lobotomy operation, let me know and I'll provide you with all my JBL stereo settings so that you can try them as a starting point afterwards. I remember it sounded mighty strange at first after I disconnected the center speaker, but after some tweaking, I was able to get a fairly pleasant sound. The stereo is still a rip-off and doesn't sound as good as an average mid-range car stereo, but that's just our lot in life. |
I think I might be more interested in installing something to control the volume of that center speaker. Ideas?
Wow, I like the center channel but I'm not a huge audiophile like you guys seem to be.
all you need is a potentiometer from radio shack. install it under the dash, do the tweakin you want then tuck it away out of site.
By the way, you can use that spot for a navigation powered speaker if you want to get rid of it completly, all you need to do is to figure out how to mute the sound system when it speakes |
Quote:
Quote:
I do alot of installs on after market stuff for work and all the switches and knobs dont look cleen to me. Maybe you can use a second factory light dimmer switch??? Thats all |
A 2nd factory light dimmer!? I'm there. Think that will work?
I want to keep it stock looking too if at all possible. But I still maintain that to get the best sound out of this unit - sit in the back seat! LOL |
Quote:
Quote:
You pick up the mid-ranges, the woofer & the rear tweeters best there, and it sounds awesome & completely surround. |
Quote:
Bottom line is this is a great fix for the sound. I drove home tonight enjoying the stereo much more now that that center speaker wasn't blaring so much. It's nice at about an additional ohm or two of resistance - there but not screaming. |
TeryT, I'm not sure about the impedance of the center speaker, but if it is 4 or 8 ohms and now the amp sees a 25 ohm load, sooner or later you may cook the amp. You really need something that changes the volume while showing the amp a constant load - like the in-wall volume controls for whole-house audio systems. Little big for a T4R if you want to be able to access it, though.
Quote:
Does that sound OK? What about just leaving the speaker disconnected (which would be the 2nd best option)? |
| All times are GMT -4. The time now is 08:23 AM. |
Copyright ©2000 - 2026, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2026 DragonByte Technologies Ltd.
User Alert System provided by
