Contemporary VIN Decoder
VIN decoder for all vehicles sold in North America 1981 onwards
The seventeen numbers found on all vehicles manufactured or imported into the US and Canada since 1981 can be decoded like this: 1st character- Identifies the country in which the vehicle was manufactured. For example: U.S.A. (1 or 4), Canada (2), Mexico (3), Japan (J), Korea (K), Great Britian (S), Germany (W), Italy (Z) 2nd character- Identifies the manufacturer. For example; Audi (A), BMW (B), Buick (4), Cadillac (6), Chevrolet (1), Chrysler (C), Dodge (B), Ford (F), GM Canada (7), General Motors (G), Honda (H), Jaquar (A), Lincoln (L), Mercedes Benz (D), Mercury (M), Nissan (N), Oldsmobile (3), Pontiac (2 or 5), Plymouth (P), Saturn (8), Toyota (T), VW (V), Volvo (V). 3rd character- Identifies vehicle type or manufacturing division. 4th to 8th characters- Identifies vehicle features such as body style, engine type, model, series, etc. 9th character- Identifies VIN accuracy (check digit). 10th character- Identifies the model year. For example: 1988(J), 1989(K), 1990(L), 1991(M), 1992(N), 1993(P), 1994(R), 1995(S), 1996(T), 1997(V), 1998(W), 1999(X), 2000(Y)------2001(1), 2002(2), 2003(3) 11th character- Identifies the assembly plant for the vehicle. 12th to 17th characters- Identifies the sequence of the vehicle for production as it rolled off the manufacturer's assembly line. The VIN is usually found on the dashboard on the driver's side. It is also found on the driver's side door post near the striker plate. The VIN may also be found on major components of some high-theft cars. |
thankx
good info..
Specific info for the 2006 4Runner:
Digits 1-2: Manufacturer and Country JT = Japan Toyota Digit 3: Vehicle Type E = Truck Digit 4-8: Vehicle Description Digit 4: Z = 2WD, B = 4WD Digit 5: U = V6 (1GR-FE), T = V8 (2UZ-FE) Digit 6: 1 = 4Runner Digit 7: 4 = SR5 or Sport, 7 = Limited Digit 8: R = 4Runner Digit 9: Check Digit Digit 10: Model Year 6 = 2006 Digit 11: Plant 0 = Toyota Motor Japan - Tahara 8 or 9 = Toyota Motor Japan - Hino Digit 12-17: Serial Number |
This should help.
You must TYPE in your VIN / not copy/paste http://fleet.toyota.com/html/vin_decoder.asp |
hey guys, that vin decoder is very cool. i typed in my vin and for some reason it said my T4R is 2wd, (which its not) my 4th digit in is B and they say that is 2WD? anyone else run into this?
Quote:
http://fleet.toyota.com/html/50/vehi...ailability.asp |
THE VIN VECODER HAS MOVED ... GO HERE:
http://fleet.toyota.com/html/50/vin_decoder.asp |
Has the VIN configuration changed for 2008?
Thanks, |
The vin decoder at http://fleet.toyota.com/html/50/vin_decoder.asp has not been updated since 2006 (as that is the last year in the file).
Someone at Toyota Fleet should update this ... but you can do it yourself if you know how to use a text editor. Save the vin_decoder.asp on your computer and edit it. Unfortunately, unless you post the vin_decoder.asp file on a web site no one else can use it. There are other changes besides the year because they have added different engines, body types etc. These items are in the owners manual. |
Anyone know if there is a Toyota VIN decoder that will recognize VIN's up to and including 2009?
Vin decoder
This vin decoder works ... at least it worked for my 2008 nodel.
http://www.motoverse.com/tools/vin/toyota.asp Good Luck |
how to identificate if my 4 runner is highlander 4runner?
I have a 4runner srs but I want to know how identificate a highlander? of which are the main differences between that or limited or srs? thanks
another vin decoder
This decoder seems to provide more info than most. Decode This! Universal VIN Decoder - Your Own VIN Decoder
if you want a copy of the old toyota decoder that they removed from their site pm me. The toyota decoder works well up to 2006 or so. http://www.glocktalk.com/images/smil...ncinsmiley.gif |
More VIN info
Also, here's a wiki with VIN info if the decoders break.
Vehicle Identification Numbers (VIN codes)/Toyota/VIN Codes - Wikibooks, open books for an open world |
Here's the community Toyota VIN decoder. It shows factory options and extended tech specs.
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
