hre814 |
03-02-2005 05:09 PM |
Now I have another rattle!!! This one is coming from the middle of the very front part. Anyone with a history of this rattle?
Thanks!
hre814 |
03-02-2005 05:12 PM |
by the way, i removed anything that was in the sunglass holder, and it continued. only happens with the roof closed.
Jim_Chow |
03-03-2005 01:04 AM |
Is there any way to get the 4Runner w/o a moonroof? Which version?
hre814 |
03-03-2005 08:33 AM |
that's a good question, I'd look into it unless you are completely in love with the idea of a sunroof.
makakio |
03-04-2005 01:34 PM |
Thanks
GREAT SOLUTION. Thank you thank you - was beginning to go nuts over this on my '01.
Matt
Sac State |
04-19-2005 02:55 PM |
35K miles and three trips to the dealer fixed my sunroof rattle.
whew!
hre814 |
04-19-2005 03:00 PM |
what was wrong with it? also my dealer recently told me that 'rattles' are warrantied for the first 20,000 miles. Is that correct? I thought it fell under the 3 yr 36 K. They said that if there was a defect that it would be covered by the warranty, but if something simply needed to be tightened down that they would charge me a fee to look and to fix it. Is this true?!
Sac State |
04-20-2005 02:58 PM |
The sunroof had a constant rattle eminating from the overhead light assembly and along the channels. The dealer replaced the two black plastic snapin pieces and installed felt behind and around the light and it looks like they installed two bright aluminum rails on the inside of the channel.
I had it in for the plastic pieces, which were ordered, and when I got my rig back they said there was another TSB being offered and they performed that one for me also.
I involved the service manager when it wasn't fixed the first two times. The first time they didn't even look at it. Amazing how involving the service manager and giving them a black eye on the Toyota survey made them look a little harder at my problem.
I've been mentioning this problem starting at the 10K mile mark, if they tried to charge me somebody would have been missing a few front teeth.
Ahem, when I got my rig back from the porter there was black grease smeared all over the grey door sill. :mad:
RXvedub |
05-25-2005 04:09 AM |
I WAS going to get a sport 2wd V8 with no sunroof, but didnt like the fact my dad had one on his sr5 and i didnt, also in southern california its manditory in my opinion
colo4runner |
08-12-2005 06:05 PM |
Herman, I have a rattle coming from the same area you mentioned - on top on the ceiling but the sunglass holder. Sounds like it is coming from behind the sunglass holder and the two lights up there.
Mine rattles with sun roof open or shut. Any ideas?
How hard is it to take out that sunglass holder/light assembly so I can look underneath there?
Thanks. - yes, there is nothing in the sunglass holder.
Borderfolle |
11-17-2005 10:10 PM |
I used the nylon washer fix for my sunroof rattle and it worked great. Thanks WhiteSR5 for sharing your repair on this message board. It's what makes this such a good site!
RXvedub |
11-18-2005 02:47 AM |
Mine just developed this rattle
a3fnqpjw |
11-18-2005 08:44 AM |
WOW, i got my 05 in February, I got the sunroof on mine, but so far (9 mos.) and i havent had one problem with it. not one rattle, not one thing wrong with the sunroof, or with the vehicle. Maybe i just got lucky :D
jmatlas |
05-04-2006 02:22 PM |
I have '03 4runner limited V8 with the dreaded sunroof rattle, only when closed. Right behind driver's head. I've read the previous messages about possible fixes --- rubber or plastic tubing, or washers, or felt tape. But where/how do I put those? Thanks.
toybox |
05-04-2006 03:21 PM |
I'm assuming you are out of warranty? Because it was a warrantable item.
Find out the fix kit part number from some one (I can look at my reciept if you would like) and order it from partznet and do it yourself. There is a TSB on this and it will give you a basic idea of how to fix and the parts and tools needed to fix it. Search for the '03 sunroof TSB.
Search Engine Optimisation provided by
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
Advanced User Tagging (Lite) -
