Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 07-28-2011, 12:45 PM #91
martini's Avatar
martini martini is offline
martini is on a distinguished road
martini's Avatar
Give this a try: Drivers seat feels a bit loose but dealership says they can't see anything wrong.
Originally Posted by DocMT View Post
I had a sunroof rattle that was driving me crazy until I finally figured it out.
Does your sunroof rattle go away when you have the sunroof in the open position (popped up, not slid open)? If so, then try this:
Open the sunroof all the way (slid open) and wipe out the channel where the seals on your sunroof rest against the paint. Clean it really good. Now wipe down the seal around the sunroof. You can clean the front edge while it's still slid open, but then you'll have to close it and pop it up to get to the sides & rear edge. Anyway, the point is to make sure you wipe it down all the way around. Once you do that, take some silicone spray on a rag and wipe down the entire seal again.
I did that more than a year ago and my rattle never returned. The whole time I thought part of the sunroof linkage or mechanism was causing my rattling noise, and it was just the seal that needed to be cleaned. If your problem is similar, give it a shot...it definitely worked for me.
I tried it last night, and go figure it worked! So far today I haven't heard a sound from the roof at all. I would never have guessed cleaning around the glass and roof would make such a difference. I'll report back with additional results in a few days.
2007 4Runner Sport V6 4WD Shadow Mica, Tint, Extended differential breather, Carbon filter removed, Bilstein 5100s - 0 setting with Old Man Emu 884s, ToyTec Superflex coils and 5100s rear, Dobinsons UCAs, P265/70/17 Michelin Defender LTX M/S, Spidertrax, Xtreme Phillips 4300K HIDs, ICON Sway Bar Relocation Blocks
Former 1999 4Runner Highlander V6 4WD Black
martini is offline   Reply With QuoteReply With Quote
Old 09-29-2011, 11:15 AM #92
martini's Avatar
martini's Avatar
A follow up to my previous post on this. Just using a wet rag did fix the problem for a few weeks but then returned. I recently wiped down the seal around the sunroof again and the rattle again is gone.
Old 10-11-2011, 10:05 AM #93
Slider's Avatar
Slider Slider is offline
Slider is on a distinguished road
Slider's Avatar
Going to give this a try on my wife's '07, probably tomorrow. Seriously annoying.
Slider is offline   Reply With QuoteReply With Quote
Old 11-05-2011, 01:36 AM #94
Jester4kicks Jester4kicks is offline
Jester4kicks is on a distinguished road
Just did this to mine today! Worked great! (Although I think the lack of this rattle has made the rattling dome light more evident.)
I ended up using a rubber grommet instead of a nylon spacer. It worked, but I opened and closed the sunroof a few times while watching it. What I noticed was that with each open/close, the spacer would slide just a little bit in the track, and a little bit along the rod. This eventually led to the grommet being pushed toward one end or the other on the rod.
Has anyone else experienced this? Anyone found a good fix?
2006 V6 SR5 4WD - OME 885, Toytec Superflex rear coils + Daystar 1.5" spacer on driver's side to eliminate sag, Nitrocharger 90000/60004 shocks, Spidertrax 1.25" spacers, 285/70/17 Firestone Destination A/T's, Spenski Off-road cargo barrier, Whitson Metalworks roof rack, Shrockworks sliders
Jester4kicks is offline   Reply With QuoteReply With Quote
Old 11-24-2011, 01:24 PM #95
knightsfs4's Avatar
knightsfs4 knightsfs4 is offline
knightsfs4 is an unknown quantity at this point
knightsfs4's Avatar
My sunroof cover is the only thing rattling. When I open and close my door it rattles but it I hold the cover it doesn't make any sounds. Anyone fix this?
Jack
knightsfs4 is offline   Reply With QuoteReply With Quote
Old 10-12-2012, 09:40 PM #96
dougmaz dougmaz is offline
dougmaz is on a distinguished road
Originally Posted by WhiteSR5 View Post
OK, here are the pictures for the fix, sorry I took so long.
This first picture is of the general area. Note that this fix needs to be done to both sides of the vehicle. And even though the sounds you might here sound like they are coming from somewhere else (much like mine did) this is actually where they are originating.
i am trying to view the pictures in your post and for some reason I can't seem to view them. I am getting a rattle in the back of my sunroof mechanism behind the driver just like you did and I want to try to fix it before forking over $2K for a new sunroof to the dealer. Can you repost the pictures? Thanks!
dougmaz is offline   Reply With QuoteReply With Quote
Old 10-12-2012, 10:32 PM #97
R.A. R.A. is offline
R.A. is on a distinguished road
The pictures are there but do not show with IE. Use another browser like Firefox.
R.A. is offline   Reply With QuoteReply With Quote
Old 11-20-2012, 11:03 AM #98
scootermcrad's Avatar
scootermcrad scootermcrad is offline
scootermcrad is on a distinguished road
So, I guess I've got the same rattle and I suspect mine might be leaking as well. I get wind noise and when driving in a good downpoor I can see it dripping off the edge to... well... I don't even want to know where.
Is their a more current thread on this? I have an '07 and I've only had the dealer give me some line that they had to replace the glass and I would have to spend $$$. I'm pretty mechanically inclined and have machining tools to make stuff if needed. Will it come down to that? Anyone have luck with Toyota fessing up and taking care of out of warranty issues like this one?
HELP! Anyone!
scootermcrad is offline   Reply With QuoteReply With Quote
Old 10-18-2013, 10:05 PM #99
lambohaha's Avatar
lambohaha lambohaha is offline
Real Name: Avery
lambohaha is on a distinguished road
lambohaha's Avatar
Real Name: Avery
Will be giving this a shot. I can physically move the rear of the sunroof up when it is closed and my rattle stops so it could be this bar flexing too much not giving the necessary load to make the sunroof fit tight like its supposed too.
"My neighbors listen to good music whether they like it or not"
lambohaha is offline   Reply With QuoteReply With Quote
Old 10-24-2013, 07:47 PM #100
subspd's Avatar
subspd subspd is offline
subspd is on a distinguished road
subspd's Avatar
X2^ Mine also move up and down and I can replicate the rattle by moving it myself I can also stop the rattle by just lightly pushing up on it. I got a video I will post on YouTube.
Has anyone else tried the zip cable method for this fix?
2007 Limited 4x4 V6
Front: Taco TRD struts + 1" spacer - Rear: 2" Superflex w/ driver 1.5" spacer TRD shocks - eBay UCAs - Lots of lights
Past: 1996 FJZ80 LX450 Locked OME
1999 UZJ100 Locked
2006 Tacoma Prerunner SR5 5100s TRD rear leaf
subspd is offline   Reply With QuoteReply With Quote
Old 02-08-2014, 07:29 PM #101
jayhawkbrandon jayhawkbrandon is offline
jayhawkbrandon is on a distinguished road
Tips and problems
I just tried this on my 2007 4Runner Sport. For those that have this vehicle, here are a few things that might help:
1) If you have access to a pet store, buy the silicon tubing that they use for air pumps. The black tubing costs about $3 and snaps around the little bars perfectly.
2) I used graphite grease on mine.
Although the tubing fits perfectly, the rattle is still there on my vehicle. I'm going to try to wipe down the seal.
jayhawkbrandon is offline   Reply With QuoteReply With Quote
Old 03-23-2014, 11:05 PM #102
ellroy2 ellroy2 is offline
ellroy2 is on a distinguished road
After years of this rattle, I have finally had enough. I have been driving on bumpy roads lately which has magnified the noise. I first tried the washer/spacer on the guiderail. I then tried cleaning and greasing, but it is still there. Today I think I finally isolated the area. As you can see in the pic, there is a rivet that runs through these pieces. When I press on it I can hear a faint noise that sounds like the rattle. Also when driving, I can press on it and the rattle will stop. Any ideas on how to fix it?
Rattling noise on ceiling-p1000480-jpg
ellroy2 is offline   Reply With QuoteReply With Quote
Old 12-05-2014, 03:55 AM #103
Oneluv13T4R's Avatar
Oneluv13T4R Oneluv13T4R is offline
Real Name: Miah
Oneluv13T4R will become famous soon enough
Real Name: Miah
Rattle gone!!!
The nylon washer worked perfect...
Silence at last..thank you
Oneluv13T4R is offline   Reply With QuoteReply With Quote
Old 12-05-2014, 10:19 AM #104
martini's Avatar
martini's Avatar
Would you mind posting a picture showing the end result to compare to the picture above please?
Old 03-19-2015, 09:00 PM #105
The Beast's Avatar
The Beast The Beast is offline
Real Name: John
The Beast is on a distinguished road
The Beast's Avatar
Real Name: John
So the wife never lets me drive her 4Runner but today I had to drop my car off for service wont get it back till mon, so on the way home this rattle was driving me nuts she's hard of hearing so never mentioned it to me, I'm thinking I'm needing to drive this for the next 4 days I'm gona loose my mind. So again I check on T4R.ORG and you guys have a fix! I didnt have any tubing but I had a small piece of a rubber floor mat I trimmed and curled it around that tube on both sides , drove it rattle gone !!!
Thanks guys !
John
2003 4Runner Limited 4.7L 119k Wife's ride (The Beast)
2007 Mustang GT Premium Convertible
1998 Chevy Silverado K1500 5.7l
1993 Jeep Wrangler 4.0l to plow the driveway
The Beast is offline   Reply With QuoteReply With Quote
Rattling noise and vibration Eleanor Classic T4Rs 3 11-20-2009 11:54 PM
weird rattling noise on 08 4runner useport80 4th Gen T4Rs 4 08-05-2008 12:08 AM
rattling noise tortex53 Classic T4Rs 0 09-25-2006 03:22 AM
Rattling noise from front wheel Big E 4th Gen T4Rs 6 05-11-2006 07:02 PM
rattling noise coming from roof nasdaqer 4th Gen T4Rs 5 02-04-2006 12:22 PM
