Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 12-18-2019, 12:17 AM #151
Jasonredwood's Avatar
Jasonredwood Jasonredwood is offline
Jasonredwood is on a distinguished road
yeah upload pictures. My rattle is back.
Jason
1985 fj60
2006 4runner v8 4x4 sport
http://www.jasonredwoodart.com
Jasonredwood is offline   Reply With QuoteReply With Quote
Old 12-22-2019, 01:35 AM #152
4x4Runnr 4x4Runnr is offline
4x4Runnr is on a distinguished road
Originally Posted by thegame7 View Post
Just as an update to this, I was having a gnarly sunroof rattle and found it would go away if I pushed up on the glass. Decided to try putting tape on the body around the back side of the glass and found that 3M Super 33+ electrical tape works great. I cleaned the sheet metal with denatured alcohol and stuck a couple layers of tape on and no more rattles. I think what happens is over time the seal gets old, dry and shrinks from constantly being in the elements. Combine that with the hinges that get loose over time and you have a rattling sunroof. Sucks we can't just put a new seal on but the tape works. Black electrical tape certainly looks better than the white medical tape someone used earlier in the thread LOL Now to fix the rest of the rattles in the rear passenger area
Gonna try black electrical tape when my Durapore wears out. I just used it because that's what worked getting rid of the rattles in the dash of my Tundra. Can't see it when the sunroof is closed anyway. Does the adhesive on the electrical tape maintain adhesion when the summer comes and the roof gets super hot?
4x4Runnr is offline   Reply With QuoteReply With Quote
Old 12-07-2020, 02:40 PM #153
alia176 alia176 is offline
alia176 will become famous soon enough
My '03 has sliding glass has been rattling since I've owned it and found a '04 in the junk yard so I pulled the sunroof cassette. I'm hoping by swapping out the '04 unit into my '03, the annoying rattle will cease. I just read the TSB on curing this rattle but failed to inspect the '04 unit to see if the TSB was applied to it at the factory.
Anyway, I"m keeping my fingers crossed.
Here's the TSB for folks to refer to as necessary. It speaks of doing some simple things but the main thing is the lack of lubrication under the wind deflector guide block. It also shows the placement of a plastic/vinyl tubing around the wind deflector guide rod. Some folks put plastic washers or rubber grommets around this rod to decrease their rattle.
While the headliner was dropped, I took the opportunity to clean the rodent nest that was on top, run the video camera wire along the ceiling edge to the front, wash all plastic interior panels in the bathtub, vac/clean years of offroading dust from behind the plastic interior panels and finally, apply Rattle Trap sound deadening matt to the ceiling and to the sides.
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 with whole bunch of stuff!
alia176 is offline   Reply With QuoteReply With Quote
Old 12-07-2020, 06:02 PM #154
USA591's Avatar
USA591 USA591 is offline
USA591 is on a distinguished road
USA591's Avatar
I'm curious about your experience dropping the headliner...what it a huge pain in the rear?
2009 T4R V8 Lmited
Kenwood TM-V71
Icon Stage 4
275/70R17 KO2's
USA591 is offline   Reply With QuoteReply With Quote
Old 12-15-2020, 05:55 PM #155
I don't think it was a PITA, say, compared to dropping the Tcase Admittedly, I practiced in the junk yard when I pulled the sunroof cassette so I was more confident and took a lot of pics.
One of the biggest thing to dropping the headliner is not to break it. I mean you can bend it but don't want to put a huge crease on it. I tied straps and rope around the whole roof/ceiling to support the headliner and to support the sunroof cassette during removal and installation. The headliner can't be easily removed from the vehicle due to the wiring harness that goes to the second row dome light and the entertainment system console gizmo. This harness is glued to the backside of the headliner. Nice going Toyota!
There are four color matched plastic clips toward the middle and rear of the ceiling that should be popped out using a trim removing tool. This is the tool with a Y at the end of it. I used a piece of 1/16" alum plate to pry this tool against as I didn't want to dimple the headliner.
Toyota is using velcro around the perimeter of the sunroof opening to keep the headliner attached to the sunroof cassette.
Here's a pic of the headliner, harness and a mouse nest!
Shared album - A. Ali - Google Photos
Here's a pic of the sunroof cassette being supported by the straps
Old 12-15-2020, 05:57 PM #156
Well, I STILL have the sunroof rattle with the '04 sunroof cassette that I swapped in. Sounds like the TSB wasn't applied to this '04 4runner so I'll do what TSB is suggesting.
I'm very annoyed.
Old 12-15-2020, 06:33 PM #157
USA591's Avatar
USA591's Avatar
Headliner Pix
Rockstar! Thanks for posting those pix--enormously helpful.
2009 T4R V8 Lmited
Kenwood TM-V71
Icon Stage 4
275/70R17 KO2's
Old 06-07-2021, 07:31 PM #158
tp0908's Avatar
tp0908 tp0908 is offline
tp0908 is an unknown quantity at this point
tp0908's Avatar
Moonroof rattle
Like most of you who struggled to get rid of the moonroof rattle. I have tried most of the suggestions incuding the TSB. But did not solve the problem. The only one that I did not do was to pull down the headliner and inspect for anything loose. That's just too much work.
I just like to share how I got rid of the rattling noise. I used a plastic melt glue stick and cut it 36mm length and put it between the aluminum rail and the moonroof metal frame (that holds the glass). Be aware that you must remove the glue stick if you want to open the moonroof.
Recent project I did: Replaced my headunit with ATOTO SA102 (with Carplay). I am very happy with it. I bought refurbished on ebay (ATOTO USA) and got what looked like brand new (complete with protective plastic on the screen) for less than $100. Carplay boots fast using my iPhone Xr. Works great with Google Map and Waze GPS. And, it you have SynologyNAS, it also have and interface for Synology DS Audio. The Head Unit sounds great too with BASS-MID-TREBLE control plus Graphic Equalizer (with 3 memory settings). If you have powered subwoofer, SA102 have pre-out and auto-on switch for external amp/subwoofer.
Rattling noise on ceiling-hot-melt-glue-stick-jpg  Rattling noise on ceiling-alum-rail-jpg  Rattling noise on ceiling-atoto-carplay-jpg  Rattling noise on ceiling-google-map-jpg  Rattling noise on ceiling-audio-interface-jpg
2004 SR5 Black
tp0908 is offline   Reply With QuoteReply With Quote
Rattling noise and vibration Eleanor Classic T4Rs 3 11-20-2009 11:54 PM
weird rattling noise on 08 4runner useport80 4th Gen T4Rs 4 08-05-2008 12:08 AM
rattling noise tortex53 Classic T4Rs 0 09-25-2006 03:22 AM
Rattling noise from front wheel Big E 4th Gen T4Rs 6 05-11-2006 07:02 PM
rattling noise coming from roof nasdaqer 4th Gen T4Rs 5 02-04-2006 12:22 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
