Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 10-06-2003, 08:07 AM #1
T4RLTD03 T4RLTD03 is offline
T4RLTD03 is an unknown quantity at this point
Rattling noise on ceiling
Hey guys,
I been noticing some rattling noise on the ceiling behind the driver side at the end of the sunroof. Everytime I drive over a bump, I would hear the noise. It seems like there's something lose in the ceiling. If I put my hand on it and push it up, I don't hear the noise. Anyone experience this or know what I can do about it?
Thanks..
T4RLTD03 is offline   Reply With QuoteReply With Quote
Old 10-06-2003, 09:27 AM #2
WhiteSR5's Avatar
WhiteSR5 WhiteSR5 is offline
WhiteSR5 is on a distinguished road
WhiteSR5's Avatar
I had the same problem with my wife's 03 4Runner. It was driving me nuts, and it sounded like it was coming from behind the sunroof on the drivers side. But what it ended up being was the sunroof track itself.
I will post some pictures when I get home tonight outlining exactly how to fix the problem.
WhiteSR5 is offline   Reply With QuoteReply With Quote
Old 10-06-2003, 05:22 PM #3
Greenhorne's Avatar
Greenhorne Greenhorne is offline
Registered User
Greenhorne is on a distinguished road
Registered User
Greenhorne's Avatar
Please do post the pic's... it would help me also.
Greenhorne is offline   Reply With QuoteReply With Quote
Old 10-06-2003, 05:50 PM #4
trsnrtr trsnrtr is offline
trsnrtr is an unknown quantity at this point
If it was in the front, I'd suggest removing your sunglasses from the sunglass tray in the ceiling.
trsnrtr is offline   Reply With QuoteReply With Quote
Old 10-06-2003, 09:47 PM #5
tkr128's Avatar
tkr128 tkr128 is offline
tkr128 is on a distinguished road
tkr128's Avatar
I've got the same rattle! It's beginning to get louder and louder.
2003 4Runner SR5 V6 4x2 - Pacific Blue Metallic/Taupe Leather
tkr128 is offline   Reply With QuoteReply With Quote
Old 10-07-2003, 09:20 AM #6
WhiteSR5's Avatar
WhiteSR5's Avatar
OK, here are the pictures for the fix, sorry I took so long.
This first picture is of the general area. Note that this fix needs to be done to both sides of the vehicle. And even though the sounds you might here sound like they are coming from somewhere else (much like mine did) this is actually where they are originating.
Rattling noise on ceiling-104_0477m-jpg
Old 10-07-2003, 09:24 AM #7
WhiteSR5's Avatar
WhiteSR5's Avatar
This next picture shows a close-up of the problem area. Note the round bar that runs down this channel. This bar controls the movement of the wind deflector. So it moves forward and backward down this channel. The reason I believe that some people are having this rattling problem and others are not is due to the fact that if the sunroof is not adjusted just perfectly, than this bar has some load on it, which causes it to flex slightly bringing it closer to the channel edge.
Rattling noise on ceiling-104_0481m-jpg
Old 10-07-2003, 09:27 AM #8
WhiteSR5's Avatar
WhiteSR5's Avatar
This next picture is of the nylon spacer that I used to fix the problem. You can pick up these spacers at most hardware stores.
The spacer dimensions are:
3/8" outside diameter
3/16" inside diameter
1/8" thick
Rattling noise on ceiling-104_0485m-jpg
Old 10-07-2003, 09:29 AM #9
WhiteSR5's Avatar
WhiteSR5's Avatar
And this last picture is of the spacer installed. Note that you don't want to spacer to be too tight or it will not allow the bar to move freely.
Rattling noise on ceiling-104_0478m-jpg
Old 10-07-2003, 09:33 AM #10
If I bring this to the dealer, will they fix it for me?
Old 10-07-2003, 09:50 AM #11
Old 10-07-2003, 10:03 AM #12
WhiteSR5's Avatar
WhiteSR5's Avatar
Probably not, I showed it to my dealer so they could tell Toyota and maybe come up with a more refined fix. But they seemed to not really care.
Old 10-07-2003, 04:43 PM #13
Old 10-07-2003, 08:39 PM #14
Avian Avian is offline
Avian is an unknown quantity at this point
Give the dealer a try. I took mine in and it seems as if the problem is resolved for now. However, I seem to now be hearing a vibration or rattle from the front driver's side door....very, very inconsistent at this point. Will wait and see what happens with this.
Avian is offline   Reply With QuoteReply With Quote
Old 10-08-2003, 05:28 PM #15
fileechino's Avatar
fileechino fileechino is offline
fileechino is an unknown quantity at this point
fileechino's Avatar
WhiteSR5,
I tried your homemade remedy....THANK YOU! I found a spacer as close to the dimensions as you suggested and so far no more rattling! I still can't believe that for 50 cents and about 5 minutes, I was able to stop a rattling that the dealership suggested would be "an all day" fix.
I hope others will give your remedy a try
fileechino is offline   Reply With QuoteReply With Quote
Rattling noise and vibration Eleanor Classic T4Rs 3 11-20-2009 11:54 PM
weird rattling noise on 08 4runner useport80 4th Gen T4Rs 4 08-05-2008 12:08 AM
rattling noise tortex53 Classic T4Rs 0 09-25-2006 03:22 AM
Rattling noise from front wheel Big E 4th Gen T4Rs 6 05-11-2006 07:02 PM
rattling noise coming from roof nasdaqer 4th Gen T4Rs 5 02-04-2006 12:22 PM
