Old 05-10-2005, 01:23 AM #1
TeryT's Avatar
TeryT TeryT is offline
TeryT is on a distinguished road
TeryT's Avatar
VSC Light Stays On
Was wondering if anyone ever had this issue: loading up the 4Runner and having the VSC light stay on?
On a couple instance lately, we have loaded it up - without a trailer - and the light comes on when on the road. It doesn't go off until I turn the ignition off (for instance when refueling - not when we unload). I figure with me, wife, dog, gas & a few supplies, we may be approaching 950 lbs. The payload limit is about 1200.
Anyway, the dealer says they can't do anything as the light is out by the time I can get it to them, and the codes are erased. The one code that was in there suggested that the vehicle was riding too low. I figure this was when we rented a trailer with a 500 lb. tongue weight. A that point we probably were very close to the 1200 lb. limit, and I do remember the VSC lights staying on then.
I've got 2000 miles left on my warranty, and about 6 weeks before our travel trailer comes in. Hoping to figure it out before then!
Suggestions? Thanks!
2003 V8 4x4 Sport 4Runner TRUCK OF THE MONTH SEPT. 06 - still tows a 25' ultralite Rockwood 2502 travel trailer all over creation!
MODS: GlowShift tranny temp gauge; Hayden 526 tranny cooler/fan combo; Hopkins Insight brake controller; Bilstein 5100 shocks
Hensley Arrow hitching system - quite simply the best for zero sway towing!
TeryT is offline   Reply With QuoteReply With Quote
Old 05-10-2005, 02:01 PM #2
Good Times's Avatar
Good Times Good Times is offline
Good Times is on a distinguished road
Good Times's Avatar
there is no way your codes will clear since you have an obd2 computer.
is the cel (check engine light) coming on as well?
the vsc should have nothing to do w/ veh payload as i've loaded my truck w/ lots of goodies (including all the armor) and no vsc light.
something sounds fishy.
Good Times is offline   Reply With QuoteReply With Quote
Old 05-10-2005, 04:26 PM #3
TeryT's Avatar
TeryT's Avatar
obd2 computer? Is that better than an r2d2? LOL Sounds like you know about these. They are saying it only contains "hard codes," like the one that said it was riding too low, or unlevel.
No check engine light, or anything else. Just the VSC comes on for an extended period, usually when loaded going around a corner. The light & the sound stay on for a little while, then both VSC lights come on & stay on untill I turn the engine off.
I'm thinking of loading up my in-laws & a few things this Saturday - getting up to around 1000 lbs. (including gas), and see if it happens. If so, I will take it in then so they can read the code - since they say it clears out.
Also, the service guy noticed that the rear rubber body bumper had hit the rear axle. He could tell because it was very dusty due to the dirt roads I was on while camping this past weekend. I think he was trying to say I was overloaded. But I know I wasn't, and was no more than perhaps 800 lbs. The dirt roads leading to Toroweap (remote Grand Canyon) are bumpy, but my Altima could do most of it, albeit carefully. He said he hardly ever has seen where the rubber mounts have hit the axle. I think this must be because most of the vehciles around Scottsdale never see anything close to moderate off-road conditions!
Old 05-10-2005, 04:36 PM #4
Good Times's Avatar
Good Times's Avatar
I'm not clear on what's going on here.
when you say vsc light stays on, do you mean it shows this "VSC Trac Off"? or something like that right? do you also see the X (for center diff) light on too or no?
does this light stay on even on hard surfaces too? it could be that the traction control is lit cuz it's slipping? not sure but if the vsc stays on while on the asphalt, then something doesn't sound right.
you do have the vsc button disengaged right? (have center unlocked)? just making sure since you don't have to drive w/ the center locked at all.
The codes should not clear just because you turn off your 4runner (or that's what I was led to believe.
As for the load, that shouldn't matter. My vehicle load dry weight is approximately 650# including the driver (The amount of metal I've added doesn't help me one bit). Add camping gear and approxmiately 25 gals of water and I'm talkin severely pushing the limits of the vehicle. Regardless I've never experienced anything of this kind though. sorry
It might be nothing but I'd check it out.
Old 05-10-2005, 04:46 PM #5
TeryT's Avatar
TeryT's Avatar
The VSC light comes on, then in just a little bit the VSC OFF light comes on. The two of them stay on. Acoording to the maual, when this happens there is a problem & to take it in.
It has always happened while on pavement.
Old 05-10-2005, 04:48 PM #6
Good Times's Avatar
Good Times's Avatar
sounds like it needs some lovin at the stealership. good luck
Old 05-10-2005, 05:13 PM #7
sharp4runr's Avatar
sharp4runr sharp4runr is offline
sharp4runr is on a distinguished road
sharp4runr's Avatar
mine did something similar after doing the sulfur TSB. The VSC and the VSC OFF light both illuminated. I took it back to the dealership and they had to replace a faulty sensor or something like that. I have the work order somewhere.
But basically, it never turned off, the lights where on ALL the time until I took it back to them.
sharp4runr is offline   Reply With QuoteReply With Quote
Old 05-11-2005, 03:30 PM #8
mjfrank mjfrank is offline
mjfrank is an unknown quantity at this point
Doesn't that have something to do with recalibrating the Yaw sensors?
Maybe he has a faulty Yaw sensor?
2004 4Runner SR5 4WD V8
Stratosphere Mica
  • Canadian hood guard
  • Homelink
  • Scion/Pioneer CD/MP3 stereo
  • AUX-BOX Aux input
  • TRD Dual Exhaust
mjfrank is offline   Reply With QuoteReply With Quote
Old 05-11-2005, 03:53 PM #9
TeryT's Avatar
TeryT's Avatar
I asked about the yaw sensor. The stealer tech person said it had more to do with the steering, but who knows!?
Old 01-03-2013, 07:25 PM #10
himom himom is offline
himom is on a distinguished road
I'm having a similar problem but it's when I use my center diff lock, the lights stay on even if I unlock until I shut off the vehicle
himom is offline   Reply With QuoteReply With Quote
check engine light + the VSC Trac + VSC OFF lights are on- Again 1 year later Jerold 3rd gen T4Rs 22 05-26-2010 02:11 AM
VSC light on? lawwailok 4th Gen T4Rs 5 12-26-2007 01:11 AM
VSC Light Pops on with weight distribution TeryT 4th Gen T4Rs 10 01-01-2006 06:10 PM
Thud then VSC Light '03 V6 TPiccoli Problems & Warranty Issues 6 07-14-2004 08:51 AM
