Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Old 01-05-2009, 01:12 PM #1
AquaMan's Avatar
AquaMan AquaMan is offline
AquaMan is on a distinguished road
AquaMan's Avatar
Exclamation Tailgate will not open
All, My tailgate will not open.
I took the rear tailgate panel off to clean out sand that blew into the tailgate when the window was accidentally left open. While doing so, I initially thought I could gain better access to the drivers side if I took off the electrical panel -- after removing the bolts and ONE electrical plug (to the motor that closes the tailgate) it was apparent this was not needed. I put back together and re-plugged the motor to the latch. However, when project complete and tailgate closed, the motor did not engage and now the tailgate will not open.
I attempted to "normalize" all locks and windows (per the manual), but still no luck.
Does anyone know how to get it unlocked without going to the dealer?
2007 4Runner 4WD:
-Old Man Emu suspension 885/895
-BF Goodrich Mud Terrain KM2 285's
-ProComp Alloy Series 7005, flat black 17's
AquaMan is offline   Reply With QuoteReply With Quote
Old 01-05-2009, 02:16 PM #2
Pirate VI's Avatar
Pirate VI Pirate VI is offline
Pirate VI is on a distinguished road
Pirate VI's Avatar
this happened to me when I installed my back up camera. One of the wiring harnesses ( while physically clipped in) can be a bit loose and not make contact. Try to pull the plastic off the inside of the tailate while u are in the trunk ( it is possible but a bit tricky) and wiggle and push the wiring onnectors together. When looking at it from the inside of the truck you will see one plugged into something on re right hand side ( the most obvious connector there) I would be willing to bet this fixes the problem.
Edit: after rereading your post it sounds like the wiring you unplugged and the one I am talking about are the same. That Is a good sign, go try it out.
2016 White Tacoma Double Cab Short Bed TRD Off Road
SOLD
March 2007 T4ROTM
2004 Galactic Grey, 3rd Row, Leather, Scion FR-S Navigation, Daystar 2.5 Lift, Toytec 1in BL, 285/70/17 BFG All Terrain, Thule Rack and more
Pirate VI is offline   Reply With QuoteReply With Quote
Old 01-05-2009, 03:33 PM #3
Kmvreter's Avatar
Kmvreter Kmvreter is offline
Kmvreter will become famous soon enough Kmvreter will become famous soon enough
Kmvreter's Avatar
You said "normalize". Did you do this by locking and unlocking the doors using the driver's door lock/unlock master switch? If the other doors lock/unlock and your windows power up and down then I don't think it's a fuse. Does the rear door key switch still lock and unlock the vehicle?
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
`(o)_---(o)_--)_)`.........
Kmvreter is offline   Reply With QuoteReply With Quote
Old 01-05-2009, 11:07 PM #4
AquaMan's Avatar
AquaMan's Avatar
Thanks for the suggestion, Pirate VI. Unfortunately, I just tried that again, and still no luck.
I "normalized" all the locks per the manual and they all function properly. Everything in the tailgate functions properly with the key also (window up/down, lock/unlock doors) with the exception of unlocking the tailgate itself.
Puzzling, and get a bit frustrating...
2007 4Runner 4WD:
Old 01-05-2009, 11:10 PM #5
AquaMan's Avatar
AquaMan's Avatar
Kmvreter - I tried the drivers side master door lock/unlock also to no avail. The tailgate motor itself (that auto locks/unlocks) is not engaging.
2007 4Runner 4WD:
Old 01-07-2009, 09:28 AM #6
Kmvreter's Avatar
Kmvreter's Avatar
Doesn't look to be a fuse because other things work. It still points back to the connection as Pirate VI had. Can you use a ohm/volt meter and check for power at the connetor. Not sure which wire but you should see 12V cycle on when you hit the lock/unlock. If you have that then it is the connector on the motor or the motor itself. Try to send 12V to the corresponding pin on the motor connector to see if it cycles.
You have an '07. If it is still under warranty then let the stealer work on it.
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 04-24-2010, 09:00 PM #7
loths loths is offline
loths is on a distinguished road
Did you solve the tailgate problem
Did you manage to fix the problem? I installed a read view camarna, unplugged some plug carefullly.. know the back door does not open. The window works, and the wiper too? Please let me know. Thanks!
loths is offline   Reply With QuoteReply With Quote
Old 04-24-2010, 10:48 PM #8
Mark86's Avatar
Mark86 Mark86 is offline
Super Moderator
Mark86 is on a distinguished road
Super Moderator
Mark86's Avatar
How about unplugging/replugging the battery? Maybe it is a stupid glitch that this would correct. Even though it is a long shot, I like starting with the simple things.
Mark
2005 4Runner Limited 4X4 V8 since 6/15/05 Titanium Silver with Grey Leather
Nav, XREAS, Adjustable Ride Height, Sunroof, Side Curtain Airbags, Rear Spoiler, Double Deck Cargo, Chrome Exhuast Tip, Bug Shield, All Weather Mats, Driver Side Assist Handle, Audiovox Remote Starter, 2006 Skid Plate, LED lighting- interior and running boards, USA-Spec PA-15
Click For Pictures of My Current 2005 Limited, Detailed LED Conversion Instructions, Click For Pictures of My Retired 2003 Sport
Mark86 is offline   Reply With QuoteReply With Quote
Old 04-25-2010, 12:20 AM #9
Thanks I though about it... I only opened the rear panel, unpluged the cables and installed the rear camera. I did not perform any electrical work. I just physically installed the camera and very carefully unpluged some cables... It was working fined before.
the only thing I can think of is that I did not disconnected the battery when doing all this... so with the battery on, may be someting happend when and unpluged and plugged back the cable... WHO knows...
I love the car, really do, but I much prefer the old fashion cable system.
Old 04-25-2010, 06:24 PM #10
Tailgate will not Open- PROBLEM SOLVED
Dude, YOU WERE RIGTH.. Disconneted the battery, waited about 5 minutes, connected back, tailgate door open. AMAZING! THANKS
I dont know if to praise Toyota or... cool it open, so simple to remedy, but how will you have opened the tailgate if the mechanism was damaged!
Old 07-24-2010, 03:05 PM #11
RevoRunner's Avatar
RevoRunner RevoRunner is offline
RevoRunner is an unknown quantity at this point
RevoRunner's Avatar
That fixed it for me too... thanks
Love this forum... thanks. Fixed it for me. After reconnecting... I did have to do the lock... unlock thing 3 times from the driver side too.
Black 2004 Limited 4WD V8
RevoRunner is offline   Reply With QuoteReply With Quote
Old 08-16-2011, 07:41 PM #12
piptraderfx piptraderfx is offline
piptraderfx is on a distinguished road
What does "normalize" mean??
Just bought a 2004 4runner limited yesterday and the rear hatch will not open. Looked on the forum and found multiple posts about disconnecting the battery and then "normalize" locks and then it opened. The truck didn't come with an owner's manual so I can't reference that.... please help!
piptraderfx is offline   Reply With QuoteReply With Quote
Old 08-17-2011, 12:07 PM #13
Uneek's Avatar
Uneek Uneek is offline
Super Moderator
Uneek is on a distinguished road
Super Moderator
Uneek's Avatar
Not the exact way Toyota describes it in the manual, but it's worked for me every time.
Fully open the window, continue to hold the open position of the switch for a few seconds. Then fully close the window, continue to hold the close position of the switch for a few seconds. Do this for both the driver side and rear window. Test to see if the auto open and close function has been restored. Repeat if it hasn't.
If you have a moonroof, do the same for the slide and tilt function by holding the respective sides of the switch. Test to see if the auto open/close function for slide and tilt has been restored for moonroof.
'06 Limited V6
Amy's Mom: "Who's that you're talking to?"
Amy: "It's Uneek, spelled in a 'unique' way."
Uneek is offline   Reply With QuoteReply With Quote
Old 02-15-2012, 06:52 PM #14
purrfactor's Avatar
purrfactor purrfactor is offline
purrfactor is an unknown quantity at this point
purrfactor's Avatar
so glad i found this post! some jerk smashed out the back window last friday and after the glass was replaced i was informed that the tailgate would not open. even had it added to the glass claim so if it was indeed broken it could be replaced due to the damage.
waiting to hear back after the body shop took it apart to see if they will cover a new one... read this, went out unplugged the battery, waited 5 min, plugged it back up and did all the window things suggested and lock unlock with the key fob and it worked!!!!!!
thanks guys!!! i have a dog that is going to need to get in and via the hatch due to an upcoming surgery and i was getting mad that i might be stuck buying a replacement part!!
LOVE T4R!!!!
06 Nautical Blue SR5 - Scoop Hood
her name is Rascal
08 Silver Streak Mica - SR5 PreRunner
his name is Storm
purrfactor is offline   Reply With QuoteReply With Quote
Old 04-19-2012, 08:11 PM #15
MICA4R's Avatar
MICA4R MICA4R is offline
MICA4R is on a distinguished road
MICA4R's Avatar
THANKS T4R.ORG!
2008 SE 4.0 4WD 5100's
MICA4R is offline   Reply With QuoteReply With Quote
Tailgate open height skybum02 5th gen T4Rs 8 02-20-2022 11:17 PM
'98 Rear Tailgate Won't Open DGIL4RUN Problems & Warranty Issues 4 12-16-2013 08:14 PM
how to open tailgate jonboi420 General Discussions 0 08-27-2010 11:23 PM
HELP! Tailgate wont OPEN! A10MileHusker 4th Gen T4Rs 3 12-12-2008 03:06 AM
Open the tailgate? bajjer9 Classic T4Rs 3 11-09-2004 05:03 PM
