Old 01-27-2006, 01:56 PM #16
lawtyger lawtyger is offline
lawtyger is an unknown quantity at this point
Just letting any future readers know that the posts above are right on point. Had this problem on my 2003 and now on my 2005. Kind of freaks you out the first time you make that hard right. I'm taking my 2005 in for regular maintance and to get the sulfer smell eliminated next week so I'll have them grease the steering then also.
lawtyger is offline   Reply With QuoteReply With Quote
Old 03-10-2006, 11:32 PM #17
Mr. Lambdebois's Avatar
Mr. Lambdebois Mr. Lambdebois is offline
Mr. Lambdebois is an unknown quantity at this point
Re: Not sure this is the same noise
Originally posted by ATLRunner
After reading more posts and hearing the noise again, I'm not sure we're talking about the same thing. This is a really loud, almost metal popping sound on the hard right turn. It is a little difficult to describe, but it is quite loud and sounds quite alarming when you hear it. I've also had passengers hear it and be fairly alarmed as well. Still convinced we're talking about the same thing?
I'm convinced I am hearing the same thing as you.
Did you find out what was causing it? Was it really the stops making the grinding noise? I'll lube em up tomorrow and see for myself....
I just can't picture it since the noise seems to be coming from something rotating.....
But hey if you thought the same thing and it fixed you up.... I will gladly stand corected.
Mr. Lambdebois is offline   Reply With QuoteReply With Quote
Old 03-11-2006, 10:39 AM #18
ATLRunner ATLRunner is offline
ATLRunner is an unknown quantity at this point
Re: Re: Not sure this is the same noise
I really couldn't picture the steering stops causing this noise either. It really is quite an awful and alarming sound. But I went down there with a rag and some lithium grease (took about 5 minutes) and lubed them up. Problem solved.
Also, if you read one of the older posts on this topic it appears to be a fairly old "problem," possibly dating back to 80's trucks.
I had a slight noise the other day, but I think I lubed one of the stops and not the other to see if I could reproduce it on left turns. So the right stop may be manifesting this problem now.
For the life of me I can't figure out why they wouldn't lube this as routine maintenence. Maybe they are supposed to...
2004 4Runner SR5 V6 Galactic Gray
Sunroof
Double Decker Cargo
Side Curtain Airbags
Ashtray/Lighter Kit
XM Roady2
ATLRunner is offline   Reply With QuoteReply With Quote
Old 03-11-2006, 10:46 AM #19
Ok....Lubed the stops with some grease....
I then went around the neighbor hood till I came to a turn and made a very slow tight right. The grinding noise is still there.
Only does it on tight right right turns ( before full lock).
Sounds like rivits on a caliper but is not related to applying the brakes.
I have looked all over for any obvious marking on the wheels, tires, wheel wells, and frame and see nothing.
:awais:
Old 03-11-2006, 10:56 AM #20
If you don't mind could you try this for me....
Go about 1-2 mph and turn it right untill it hits the stop and back it off some so you don't dead head your pump for too long.
I can hear the noise about 30 degrees before it hits the stop.
Very metalic......
Quiet as ever turning left .
Thanks for your input. I really appreaciate it.
Old 04-03-2006, 02:09 PM #21
dave4242 dave4242 is offline
dave4242 is on a distinguished road
I also get a beeping alarm sound (?skid sensor) when i get the noise on turning. Could this be related?
dave4242 is offline   Reply With QuoteReply With Quote
Old 04-03-2006, 06:47 PM #22
Noloc's Avatar
Noloc Noloc is offline
Noloc is an unknown quantity at this point
Noloc's Avatar
Had the exact same problem. Took it to the dealer and as it turns out the bump stop was actually out of place. They repositioned it and put some grease on it. Fixed the problem right away. So... you may need to see if the bump stop is out of spec from where it should be.
** SOLD ** 04' V6 Galactic Sport Ed. 4WD: Driver Side Grip Handle, HomeLink, Clarion CX609 HU, Titanium Grey Marble Dash Kit, OBX Racing Sports Pedals, Stainless Steel T&H Low Bull Bar & Rear Bar, Wheel Well Plugs, Hilux Rear Bumper Step Guard,Toyota Door Sill Protectors, Rear Reflector LED Mod, Painted Running Boards, 20" TRD Enkei Deep 6 (265/50/20 Hankook Ventus ST RH06 XL), Canadian Bug Shield, 06 LED Tailights, Front Tint 35%, Dueler A/T REVOs, MagnaFlow Cat Back, AFE CAI, KC Slimlite Mod, Breather Mod, Sway Bar Bushing Mod
Noloc is offline   Reply With QuoteReply With Quote
Old 04-03-2006, 07:15 PM #23
TRD04RUNNER's Avatar
TRD04RUNNER TRD04RUNNER is offline
TRD04RUNNER is on a distinguished road
what is a bump stop?? where is it located on the 4r??
2004Runner SE 4WD
Natural White
________________________________________
Factory Option:Sunroof,Valor Tip,Double Deck Cargo,Rear Spoiler,DRL,Electrochromatic Mirror,Leather
Mods:Limited Sliver RB,OEM All Weather Mats,(F)Stainless Steel Door Sill,TRD Badge,20% Tint,SuperBrightLeds.com(6)White LEDs: Dome/License/Doors/& Map Light,Custom TRD License Plate Frame,Alpine IVA D900,7"VizuaLogic ADV. LC Headrest Monitor,Escort 8500 X50 w/ Custom Mounted Smart Cord,115v switch w/ X-Power 150W Inverter,G2 Sliver Painted Caliper,REVO 265/70/17,Rear Parking Light Mod,PAC SWI-ALP,OBX Sport Pedal,Ashtray&Lighter Kit,06 LEDs Taillight,55w yellow Foglight bulbs, McCulloch 6000k HID headlight
TRD04RUNNER is offline   Reply With QuoteReply With Quote
Old 07-21-2014, 03:40 PM #24
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
yay resurrecting an 8yr old thread, good info!!
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 11-20-2020, 10:42 PM #25
KwonRunner's Avatar
KwonRunner KwonRunner is offline
KwonRunner is on a distinguished road
KwonRunner's Avatar
resurrection 2020
Loud grinding noise when making a sharp right. Will try greasing the steering stops.
2008 V6 Sport Edition 4wd
KwonRunner is offline   Reply With QuoteReply With Quote
Old 12-09-2020, 01:33 AM #26
_Moose _Moose is offline
Real Name: Hah, good one!
_Moose is on a distinguished road
Not constant in my case, only if I turn does it happen once when I back up, or maybe hit a bump too hard. Zero leaks, some say its a Ball Joint, or the Steering; I don't want to take all my skids off just to find out that it was the skid-plates shifting.
Don't mean to bump an old thread, but just want to say that where ever the original posters are, I hope you're living a healthy life and still rockin' a 4Runner.
_Moose is offline   Reply With QuoteReply With Quote
'96 4Runner makes 'humming' sound after I turn off engine-help chilly0404 Maintenance/Detailing 8 07-28-2019 08:10 PM
'91 grinding sound bueller Classic T4Rs 16 01-17-2012 01:07 PM
Clicking sound coming from left front 4WD 4R. B_N Classic T4Rs 20 10-23-2007 08:27 AM
XMSKyFi2 MOD - Better sound with wireless FM kdii02 Engines / Suspension / Wheels / Tires / Audio / Accessories 2 06-16-2005 04:40 PM
sound in 10 speaker jbl not great... juandixon Engines / Suspension / Wheels / Tires / Audio / Accessories 1 10-20-2003 04:22 PM
