Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Old 05-30-2013, 08:10 AM #61
Johnate0's Avatar
Johnate0 Johnate0 is offline
Real Name: John
Johnate0 is on a distinguished road
Johnate0's Avatar
Real Name: John
CEL, VSC and TRAC lights came on over the weekend. I had replaced the CAT new OEM in January of 2011 along with the B1 sensor. I finally got around to running the scanner on it this morning and I got the dreaded PO420 code. Oh lordy please tell me its not the CAT again. Anyone have an idea of what the average life span of the OEM CAT's are? All the research I did a few years ago told me to not even bother with an aftermarket CAT for Toyotas. I'd be pretty pissed if I had to spend another $700 on an OEM CAT. :/
I'll try resetting it and crossing fingers, but I vaguely remember smelling rotten eggs briefly at some point last week. Ugh.
ETA: Well I cleared the code with my scan tool over 4 days ago and it hasn't come back on since. Fingers crossed.
Johnate0 is offline   Reply With QuoteReply With Quote
Old 06-30-2013, 09:01 PM #62
zamboknee zamboknee is offline
zamboknee is an unknown quantity at this point
Both VSC lights and Check engine lights came on. I'll post back when it comes back from shop.
zamboknee is offline   Reply With QuoteReply With Quote
Old 07-03-2013, 04:29 PM #63
Took it to my usual shop, they tightened a battery cable and that seemed to fix it. Lights came back on.
Took it to the dealer and they said its either needing a new Valve body ($1600) or recalibrating the ECM ($200). He said that they found when recal'ing a similar year Camry that sometimes the computer would seize and need to be replaced but they haven't had to do it to Forerunner before.
Recalibrating the ECM for now, obviously, and hoping that does it.
Does anyone know how much a valve body typically is at a NON dealer shop?
Old 07-03-2013, 04:53 PM #64
ksneubec's Avatar
ksneubec ksneubec is offline
Real Name: Karl
ksneubec is on a distinguished road
ksneubec's Avatar
Real Name: Karl
You may want to have them check the sensors along the exhaust system. WHen I had this problem with my old 4th gen 4Runner a simple little sensor had come loose along the exhaust line, and this triggered the whole system to go off. Simply tightening it solved the problem.
2013 4Runner TE Salsa Red Pearl
My Baby- 2011 Jerez Black Metallic M3
Sold and Missed Dearly:2004 Toyota 4 Runner
ksneubec is offline   Reply With QuoteReply With Quote
Old 07-03-2013, 09:15 PM #65
Good to know. Thanks, ksneubec!
Old 07-14-2013, 10:19 AM #66
caveman2533 caveman2533 is offline
caveman2533 is on a distinguished road
engine lite on
My check engine lite on my 2000 4runner has been on for severalw weeks. If I reset the code by removing the battery cable it will come back on after about 20 minutes of driving. First code check lean Bank 1. I cleaned the MAF sensor but problem still exists. After clearing the check engine lite it runs like crap for about 3 minutes then smoothes out. I am going to replace the gas cap also. How can I test the O2 sensors to see if they are working properly?
caveman2533 is offline   Reply With QuoteReply With Quote
Old 07-24-2013, 08:38 PM #67
FireTiger's Avatar
FireTiger FireTiger is offline
Real Name: Sean
FireTiger is on a distinguished road
FireTiger's Avatar
Real Name: Sean
Cool
You guys are awesome! I had this issue on my 02 last week, "occurred right after my transmission flush service" ironically. I immediately checked this forum first, and found these pages discussing this apparent all too common problem.
For me, all things point to my distrust of our Toyota stealerships, but I try to be open-minded. I told them that I came in here with no problems, just getting preventative maintenance done, but left with a problem. They said it was bank 1 sensor 1.
Looking at the consistencies on here with this common problem we are sharing, among various model years, I agree with the member who says this whole thing could be, and is pointing to, "unethical practices to keep the $$$ coming into the service departments...the profit center for all car sales.
I'm going to buy the gas cap, then unplug both battery cables, since taking the negative off only cleared the codes for a minute before they all came back on.
I also read that these o2 sensors were sensitive to fluids:
From URD, "A car’s oxygen sensor is constantly exposed to a barrage of harmful contaminants that can rob it of its ability to produce an efficient reading. Engine lubricants, sealants and additives, silicone, and/or oil can damage a sensor’s element." Like I said, ironically, I was getting a transmission flush, where you have a power element and plenty of fluid movement in and around the area of these sensors.
I know I sound cynical but after two love affairs with 02 Sports, I've experienced great service and unethical service. I love the forums, real drivers who love their products, and unwary service managers who don't quite understand our love affair with our vehicles.
I'll let you know how this turns out but I'm not paying $429 for a damn sensor and labor. I'll learn to fix it myself!!
Thanks, fellas
Firefighter
FireTiger is offline   Reply With QuoteReply With Quote
Old 08-04-2013, 05:07 PM #68
Here's what happened with my VSC and check engine situation:
Needed a new solenoid and valve body in the transmission. $1200 later and the lights have gone away.
My idle is lower too now. Anyone's idle hovering around 500 rpm?
Old 08-29-2013, 03:50 PM #69
LuvrGirl LuvrGirl is offline
LuvrGirl is an unknown quantity at this point
I just got these two warning lights yesterday (check engine and vsc trac). I do have a code reader so maybe I'll check that tonight first before I do anything.
Wish me luck! I'll post back with results.
~Maria
LuvrGirl is offline   Reply With QuoteReply With Quote
Old 10-23-2013, 09:58 PM #70
TMC11755 TMC11755 is offline
TMC11755 is on a distinguished road
Check Engine Light
I am going through this now.
Changed the driver side upfront O2 sensor, dealer suggested cleaning fuel injectors, and changing air filter. I had them do that bc it has been running rough.
So far so good.
2004 4Runner Sport 4.7L v8
Toytec Ultimate 3/2 lift, UL Upper control arms
Pioneer AVH-3300BT stero
JL 5way amp
JL Stealth Box to add a little BOOM!
TMC11755 is offline   Reply With QuoteReply With Quote
Old 10-23-2013, 10:00 PM #71
Hopefully I don't need a new cat!
JL 5way amp
Old 11-03-2013, 03:33 PM #72
united4989 united4989 is offline
united4989 is on a distinguished road
Smile 2007 Toyota 4runner v6 limited VSC, Trac, Check engine lights
Thanks to all you guys in the forum for posting your feedback. I too had VSC, Trac, Check engine light came on all together. I had plan to take my 4runner to the Toyota dealership tomorrow but, decided to check the 4runner forum before I went. I opened and re-tightened the gas cap and dis-connected the positive battery terminal for a few minutes. After 5minutes or so, I reconnect the battery terminal....ooh-Lah-Lah... All the warning lights went away. By the way, this is the very first time I had these warning lights came on. (This 4runner is my 3rd one, previously owned: 2001 V6 SR5, 2003 Sports Ed V8 4x4, Now I have 2007 Limited 4X4 with factory Navigation) and still is the most reliable SUV. Thanks again 4runner comrades, good luck!
2007 Toyota 4Runner V6 4X4 Limited, Black, 70,000 miles.
Factory Navigation system.
Brake rotors upgraded with slots, vents.
Upgraded audio system with 1200 watts Amp.
Sound stream RF3.6 speaker system upgrade.
10 gauge speaker wires with 30 Fared capacitor installed.
united4989 is offline   Reply With QuoteReply With Quote
Old 11-25-2013, 11:50 AM #73
IcantDo55 IcantDo55 is offline
IcantDo55 is on a distinguished road
Same lights came on here today on wife car about 3 miles into her drive. Today was 1st cold day of the year here prob 28* dont know if that means anything. Her CEL, TRAC and VSC went on at a light and truck started running rough and would only let her do max 30mph?
Any "limp" mode you uys know about? I need to find a ode reader and go check it out. Will report back.
2006 4x2 Limited 115K
Broken sunroof, like the rest.
IcantDo55 is offline   Reply With QuoteReply With Quote
Old 11-26-2013, 05:56 PM #74
jason947 jason947 is offline
jason947 is on a distinguished road
Similar issue but different codes
Here is my story, I have a 4th gen, 2005 Sport 4X4 v6. A month ago the Check Engine, VSC and Trac lights came on. The code returned was P0456 - EVAP Control System Leak Detected Very Small Leak. I replaced the gas cap and reset the check engine light. Today the lights came back on and the idle was very rough, almost to the point of stalling.
The codes that came back this time are:
P0456
C1201 - ABS Inlet Valve Coil LF Circuit Short To Ground
P0018 -Crankshaft Position Camshaft Position Correlation Bank 2 Sensor 'A'
P2198 -Faulty Oxygen Sensor Bank 2 Sensor 1
It seems like several (seemingly) unrelated problems. Wondered if anyone ever got this combination of codes. Thanks!
jason947 is offline   Reply With QuoteReply With Quote
Old 01-16-2014, 09:48 PM #75
L.J. L.J. is offline
L.J. is on a distinguished road
Exclamation VSC,TRAC and Check Engine Light
So please help me out with some of your knowledge. I am not close to any dealership where I live. Remote small town. Will it be ok to drive the vehicle for a week or two till I can travel out to a repair place or dealership with this VSC, TRAC and Check Engine Lights on? Or will it damage the engine or ther parts in any way ?
L.J. is offline   Reply With QuoteReply With Quote
Check engine light, VSC TRAC & TRAC OFF lights crainmain Maintenance/Detailing 120 11-22-2023 07:11 PM
2002 4Runner- VSC, Trac, Check Engine lights came on today ScottDetroit 3rd gen T4Rs 17 09-18-2017 11:12 AM
Check Engine + SRS + VSC TRAC + Slip Indicator lights are all on HELP!!! 4Runner07NEWBIE General Discussions 9 01-06-2011 10:30 PM
check engine light + the VSC Trac + VSC OFF lights are on- Again 1 year later Jerold 3rd gen T4Rs 22 05-26-2010 02:11 AM
2002 4Runner- VSC Trac Check engine lights came on today ScottDetroit Maintenance/Detailing 1 10-10-2008 03:32 PM
