Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Old 11-15-2018, 04:20 PM #136
nightowl49's Avatar
nightowl49 nightowl49 is offline
nightowl49 is on a distinguished road
nightowl49's Avatar
I have an '04 SR5 V6 4WD and I got the CEL, VSC TRACK, and VSC OFF lights that came on today during a snow storm. I did not notice any loss in performance, but traffic was moving slowly. When I got home, I checked the gas cap & it was tight, but I took it and off and put it back on again to be sure.
People are suggesting to unhook the battery cables for 30 seconds but how then do I reset the power windows? I read they will not work again until re-set and I have not found an answer for this in the thread.
I am hoping this will do the trick. Thank you all.
nightowl49 is offline   Reply With QuoteReply With Quote
Old 11-27-2018, 09:03 PM #137
TRDpro4R TRDpro4R is offline
TRDpro4R will become famous soon enough
Gas cap caused mine.
Rubber O ring cracked. Replaced it with a new one and lights gone.
VSC, TRAC, and Check engine lights on-img_5855-jpg  VSC, TRAC, and Check engine lights on-img_5857-jpg
2016 TRD Pro white, Bilstein 6112 and Eibach Pro-kit 1" rear springs w/ TRD shocks on rear, Camburg ball joint UCA’s, SSS front bumper with light bar, Gobi Stealth Rack No Rise, BFG KO2 275/70/17
TRDpro4R is offline   Reply With QuoteReply With Quote
Old 11-30-2018, 01:25 PM #138
Corey.Marts Corey.Marts is offline
Corey.Marts is on a distinguished road
Exhaust issues
I'm having the same issue in my v8 limited 4runner auto parts store scan said bad rear cat. I know my passenger side manifold is cracked so any recommendations for both manifold replacement brands and y pipe brands. I was going to buy the URD y pipe
Corey.Marts is offline   Reply With QuoteReply With Quote
Old 08-26-2019, 07:31 PM #139
mountains85 mountains85 is offline
mountains85 is on a distinguished road
How to solve
Originally Posted by madmax 06 View Post
Oh, and one last thing! My wife just called me while she was on her way to work, and now all of a sudden her rear windshield wiper, defroster and wiper fluid don't work. What the???? Could this be one heck of a qwinky dink, or did something get affected by disconnecting the battery. Everything else works.
I guess I will check the fuse when she gets home tonight.
Solution:
Have her put that back hatch window all the way down, roll it all the way back up. All should be fixed.
This happens on my 2003 SR5 every time I get a new battery.
mountains85 is offline   Reply With QuoteReply With Quote
Old 09-11-2019, 12:26 PM #140
Byte Me Byte Me is offline
Byte Me is on a distinguished road
Hello, similar issue but not eactly - hopefully someone can help on this matter. Recently purchased 2003 Sport and it's showing no lights when the ignition switch is on. I also have no lights when I start the engine. However, once I put it in drive the VSC TRAC and TRAC OFF lights come on. No other lights are on. It runs and drives just fine but I want these lights gone because, obviously, the skid control isn't working.
I stopped at local auto store to run the OBDII code and it came back with the infamous C1336 - zero point calibration of YAW rate sensor undone. It's the only code which comes up.
I ran through the TSB to reset the YAW zero point numerous times but after shorting Ts and CG 4 times (or more) in 8 seconds the VSC light is NOT lit. After turning the ignition switch back on the VSC warning light is not lit so I turn the ignition switch off. I still tried connected the TX and CG and turning the ignition on but the light is still off, it does NOT go through the 4 second on and .13 second blink.
The lights still stay off until I put it in drive...any ideas?!?
Byte Me is offline   Reply With QuoteReply With Quote
Old 11-27-2019, 01:17 AM #141
taras91 taras91 is offline
taras91 is on a distinguished road
Originally Posted by boston_kevin View Post
And the Verdict is:
Oxygen sensor in back of one of the cats. Tech showed me the code on their computer when he plugged it into my 4Runner.
This is how the tech explained (and showed me) how this works. 4Runner has 4 Oxygen sensors (1 on either side of each Cat). Engine side sensor monitors "dirty air", muffler side sensor monitors "clean air". If either sensor (or either side) fails, it throws the CEL. Makes sense to this point, right? On 2004+ models (and if you had the Sulfur TSB), if the CEL is lit, it also DISABLES the VSC/TRAC systems.
So I asked the question, why disable these systems if the CEL is lit? He said he did not have a direct answer but basically Toyota thought if the CEL light was on, any system that directly put a load on the engine that wasn't necessary should be disabled (which also means that the DAC might also not work) to prevent further damage to the engine. Since the VSC/TRAC works in conjunction with the brakes which can add a load to the engine, this system is disabled.
I asked one more question (for all you modification happy people who don't like VSC). Can I purposefully disable the VSC? No (officially). (unofficially you could throw a switch on the wire from one of the sensors to spoof the computer to think the sensor failed - since this would force a CEL condition, VSC would be disabled).
THANK YOU. I am currently dealing with CEL and high fuel trips. I ordered new o2 sensors. Hopefully it fixes my issues and vsc/trc turns off like it did for you. THANKS
taras91 is offline   Reply With QuoteReply With Quote
Old 11-27-2019, 01:19 AM #142
Im having same issue. Im replacing my OT sensors to fix this. FREEZE frame data shows a P0171 code when all the lights come on.
Old 03-17-2021, 03:25 PM #143
djakpr28 djakpr28 is offline
djakpr28 is on a distinguished road
sunroof noise
i have a 2005 4Runner SR 5 and about a week ago it look like noise coming from the sunroof is like a wind noise and also it feel the sunroof vibrating these no water coming from the sunroof just the wind noise,can any person know what can cause this problem Than you
djakpr28 is offline   Reply With QuoteReply With Quote
Old 03-17-2021, 03:36 PM #144
VSC Track light
Also my VSC TRAC LIGHT are on i did buy one new cap from the dealer but lights is still on can someone can help me
Old 04-18-2021, 12:02 PM #145
mr2t_ mr2t_ is offline
mr2t_ is on a distinguished road
I have an 05 v8 Limited I've been having a strange cel w/ traction lights issue for a few years. It seems like the lights come on during the cold season (Nov/Dec) and go away when it warms up around March. I tried a new gas cap the first spring and it went away after a few starts but I can't tell if it was the warmer weather. This winter I had the light until a few weeks ago then when I filled my gas tank the lights went off instantly. I got the codes checked previously and it says brake master cylinder and some engine code. The brakes work totally fine and the engine runs great with or without the lights on. Anything weather or gas tank related that could cause the cel?
mr2t_ is offline   Reply With QuoteReply With Quote
Old 10-25-2022, 01:23 PM #146
Moist's Avatar
Moist Moist is offline
Moist is on a distinguished road
Moist's Avatar
Just got all three. Freaked me out. Gas cap is on tight, and in good condition.
Just got my oil changed about a month ago. Also went from 91 gas to 87.
Installed new parking lights and had to disconnect the battery. Had a poor connection the first install, and I drained the battery good. Second time around it's perfectly fine. Idling anywhere around 1,100 to 500 RPM. (Prly just the wild temp changes we're having here though)
Couldn't tell you if it was making any weird sounds, thing's always making a racket driving down the road.
No OBD reader tho, gotta bring it in.
Moist is offline   Reply With QuoteReply With Quote
Old 10-25-2022, 03:01 PM #147
Real Name: Skip
Real Name: Skip
Most all auto parts stores will read the codes for free.
2004 Limited V8
Old 10-25-2022, 03:06 PM #148
Moist's Avatar
Moist's Avatar
Noted for the future. Already scheduled the appointment though, will report back on what it turned out to be.
Old 10-27-2022, 02:55 PM #149
Moist's Avatar
Moist's Avatar
It turned out to be a bad gas cap & old spark plugs
Check engine light, VSC TRAC & TRAC OFF lights crainmain Maintenance/Detailing 120 11-22-2023 07:11 PM
2002 4Runner- VSC, Trac, Check Engine lights came on today ScottDetroit 3rd gen T4Rs 17 09-18-2017 11:12 AM
Check Engine + SRS + VSC TRAC + Slip Indicator lights are all on HELP!!! 4Runner07NEWBIE General Discussions 9 01-06-2011 10:30 PM
check engine light + the VSC Trac + VSC OFF lights are on- Again 1 year later Jerold 3rd gen T4Rs 22 05-26-2010 02:11 AM
2002 4Runner- VSC Trac Check engine lights came on today ScottDetroit Maintenance/Detailing 1 10-10-2008 03:32 PM
