Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Old 07-19-2005, 04:59 PM #1
boston_kevin's Avatar
boston_kevin boston_kevin is offline
boston_kevin is on a distinguished road
VSC, TRAC, and Check engine lights on
On my way home from work, all three of these lights came on and will not go out. Any ideas before I take this in for warranty service? This is an '04 SR5 V6.
boston_kevin is offline   Reply With QuoteReply With Quote
Old 07-19-2005, 05:07 PM #2
sharp4runr's Avatar
sharp4runr sharp4runr is offline
sharp4runr is on a distinguished road
sharp4runr's Avatar
Is your gas cap on tight? Seriously...
I remember reading a post where a member drove off with the gas cap off and the idiot lights came on...
sharp4runr is offline   Reply With QuoteReply With Quote
Old 07-19-2005, 05:23 PM #3
Spider5's Avatar
Spider5 Spider5 is offline
Spider5 is on a distinguished road
Spider5's Avatar
Good point. My sales guy at the dealer kept stressing this point when I bought the Runner and stated that there are numerous people coming to the dealer each week with this simple problem.
'05 SE 4x V8
Spider5 is offline   Reply With QuoteReply With Quote
Old 07-19-2005, 06:43 PM #4
Yep. Gas cap is tight (2 clicks). I removed and replaced it so we will see if this goes away tomorrow morning.
Interestingly enough, I can't get the VSC to kick in (in 2WD mode) even in sand, seems like the rear is locked... Maybe it's just my imagination... 4WD works fine (not enough sand to try kicking in VSC in 4WD or locking the diff).
Old 07-19-2005, 07:39 PM #5
Spider5's Avatar
Spider5's Avatar
Dummy Lights
I had the same type problem happen on my Lexus and it turned out to be the mass air flow butterfly that got dirty and damaged (big $$$). This could easily happen if your using one of the oil based air cleaners elements and oil builds up on the mass flow components.
'05 SE 4x V8
Old 07-19-2005, 09:15 PM #6
Bluto's Avatar
Bluto Bluto is offline
Bluto is on a distinguished road
Bluto's Avatar
Gas cap would just cause a 'check engine' light. Is anything flashing? Sounds like a sensor went bad somewhere.
Bluto is offline   Reply With QuoteReply With Quote
Old 07-19-2005, 09:42 PM #7
I noticed tonight that the check engine light comes on and stays on after I start the engine. About 15 seconds after the engine is running, the VSC/TRAC and VSC OFF lights come on and all three remain steady. I never see the VSC indicator (slippery road indicator) appear, even on wet, sandy streets while driving now... Maybe the VSC sensor went bad?
I'll contact the dealer tomorrow and update everyone as soon as I know...
Old 07-19-2005, 09:50 PM #8
ksneubec's Avatar
ksneubec ksneubec is offline
Real Name: Karl
ksneubec is on a distinguished road
ksneubec's Avatar
Real Name: Karl
Kevin,
I had a similar problem with mine. It started the day after I picked it up. Same lights went on. I ended up bringing it to the dealer THREE times before they figured it out (so you may want to suggest this to them), but it was actually a loose connection somehwere on the exhaust system.
WHY these lights would go on for THAT problem, I don't know. But in order to fix it, they literally blew fog or smoke or something down the line, until they found a small leak. They blamed it on the manufacturing process, b/c all they did was tighten the connection, and 17,000 miles later, no problems.
Hope that helps.
Karl
2013 4Runner TE Salsa Red Pearl
My Baby- 2011 Jerez Black Metallic M3
Sold and Missed Dearly:2004 Toyota 4 Runner
ksneubec is offline   Reply With QuoteReply With Quote
Old 07-21-2005, 09:04 AM #9
I have an appointment to bring it in on Monday. All the service manager said was once that check engine light is on and stays on, all other lights really don't give any indication. I will post back on Monday afternoon/Tuesday if they can find the problem. Thanks everyone!
Old 07-21-2005, 06:41 PM #10
ksneubec's Avatar
Real Name: Karl
ksneubec's Avatar
Real Name: Karl
Let us know what they tell you.
Old 07-23-2005, 12:46 AM #11
kwan21 kwan21 is offline
kwan21 is an unknown quantity at this point
Question
Man, what is up with these 4runners??? I have a 2004 4runner Sport and lastnight I had the same exact problem. I find it very ironic that we are all experiencing the same problem at the same time.
A few weeks back, my sunroof busted and I looked on this forum and it seems I wasn't alone with the sunroof problem. Sure enough other people had the same problem withing weeks apart.
kwan21 is offline   Reply With QuoteReply With Quote
Old 07-23-2005, 02:13 PM #12
sharp4runr's Avatar
sharp4runr's Avatar
Boston_Kevin. Have them look at the exhaust fittings like ksneubec mentioned. When I had my Sulfur TSB done, my VSC TRAC, VSC OFF, CEL lights went on. It took them about a day to figure it out and on the invoice it mentioned that a sensor had to be replaced. It seems too similar to what ksneubec mentioned and during the Sulfur TSB, the CATS are replaced.
Good luck and let us know what happens.
July
Old 07-25-2005, 11:52 AM #13
And the Verdict is:
Oxygen sensor in back of one of the cats. Tech showed me the code on their computer when he plugged it into my 4Runner.
This is how the tech explained (and showed me) how this works. 4Runner has 4 Oxygen sensors (1 on either side of each Cat). Engine side sensor monitors "dirty air", muffler side sensor monitors "clean air". If either sensor (or either side) fails, it throws the CEL. Makes sense to this point, right? On 2004+ models (and if you had the Sulfur TSB), if the CEL is lit, it also DISABLES the VSC/TRAC systems.
So I asked the question, why disable these systems if the CEL is lit? He said he did not have a direct answer but basically Toyota thought if the CEL light was on, any system that directly put a load on the engine that wasn't necessary should be disabled (which also means that the DAC might also not work) to prevent further damage to the engine. Since the VSC/TRAC works in conjunction with the brakes which can add a load to the engine, this system is disabled.
I asked one more question (for all you modification happy people who don't like VSC). Can I purposefully disable the VSC? No (officially). (unofficially you could throw a switch on the wire from one of the sensors to spoof the computer to think the sensor failed - since this would force a CEL condition, VSC would be disabled).
Old 07-26-2005, 10:21 AM #14
Djana Tugan Djana Tugan is offline
Djana Tugan is an unknown quantity at this point
I had exactly same problem two weeks ago with
my '04 4runner. They replaced the sensor but
ONE week later another sensor went off. It is going
to be replaced today.
Djana Tugan is offline   Reply With QuoteReply With Quote
Old 12-23-2007, 08:17 PM #15
Dc_Jeff Dc_Jeff is offline
Dc_Jeff is an unknown quantity at this point
Thanks for the update
Thanks for updating us with the diagnosis - just experienced the exact same issue on my '02 Runner this evening.
Originally posted by boston_kevin
And the Verdict is:
Dc_Jeff is offline   Reply With QuoteReply With Quote
Check engine light, VSC TRAC & TRAC OFF lights crainmain Maintenance/Detailing 120 11-22-2023 07:11 PM
2002 4Runner- VSC, Trac, Check Engine lights came on today ScottDetroit 3rd gen T4Rs 17 09-18-2017 11:12 AM
Check Engine + SRS + VSC TRAC + Slip Indicator lights are all on HELP!!! 4Runner07NEWBIE General Discussions 9 01-06-2011 10:30 PM
check engine light + the VSC Trac + VSC OFF lights are on- Again 1 year later Jerold 3rd gen T4Rs 22 05-26-2010 02:11 AM
2002 4Runner- VSC Trac Check engine lights came on today ScottDetroit Maintenance/Detailing 1 10-10-2008 03:32 PM
